Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Add page break and add format to the string using ETO
1 REPLY 1
396 Views, 1 Reply
How to add a page break in MS Word using ETO 2012?
Also I want to add mixed formatting for the text in the single line (First two words should be BOLD and rest should be in normal case). Is it possible in ETO 2012.
Santosh
1 REPLY 1
Chris.Palmatier
Check out the WordBreakWriter design for writing all kinds of breaks.
Bolding might be tougher. I don't know of a way to write a paragraph and apply formatting within the paragraph. You could try writing in two parts using WordTextWriter. Create a style in your template for the bold text, then another style for the normal text. Set the correct style parameter on each part, and use Placement :After parameter to make the strings follow in the right order.
Hope this helps.
Chris Palmatier
Customer Success Engineer
Inventor Engineer-to-Order
