• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    3 Kudos
    Chris_Rogers
    Drawing Balloons/Leaders use Workpoints
    Status: Future Consideration
    by Active Contributor Chris_Rogers on ‎10-24-2012 10:36 AM
    While using Intent for drawing creation, it would be very useful to be able to use a workpoint as an entity to attach a balloon/leader to.
    Comments
    by Employee Jon.Balgley on ‎11-02-2012 03:04 PM
    Can you do this in Inventor, interactively?  I don't think so, but maybe I'm wrong.
    I think in Intent you can get the sheet-position of a workpoint, and use that in a leader.
    Balloons are intended to "go to" some visible thing in the drawing.  In the case of balloons, that's how it tracks down the corresponding part.
    by Employee Jon.Balgley on ‎11-02-2012 03:27 PM
    Status changed to: Comments Requested
    by Active Contributor Chris_Rogers on ‎11-05-2012 07:22 AM
    No, I do not believe that you can do this in Inventor currently.
    You are correct that you can get the sheet position of a workpoint for only a leader but that is a big hassle since you will need to get the workpoint location, sheet coordinates, and then view coordinates for each.
    Yes, I agree that balloons are supposed to "go to" something.
    There are two ways to handle this:
    • Use named workpoints that are saved in the .ipt's.
    • When creating a balloon, if you are using a workpoint entity, require a part file for reference.
    Also, please see this link for another good argument: http://forums.autodesk.com/t5/Inventor-ETO-IdeaStation/quot-Nearest-quot-drawing-curve-for-IvBalloon...
    by Active Contributor Chris_Rogers on ‎11-14-2012 07:31 AM
    Any update or further questions on this Jon?
    by Employee Jon.Balgley on ‎11-16-2012 02:09 PM
    Added as an "idea" for Inventor here:
    http://forums.autodesk.com/t5/Inventor-IdeaStation/Attach-balloon-to-a-workpoint/idi-p/3702700
    In the absence of that, I think ETO is limited to the "nearest drawing curve" suggestion in the other "idea".
    IdeaStation Guidelines
    Review guidelines and best practices
    before posting a new idea
