I am having some issues with ilogic and the use of substitues. Here is my structure:
Main Level Assembly
-Sub Assembly
-Base Component
I have an ilogic rule that pushes parameters from the main level to the base component. It works well but now the assemblies are getting very large and RAM is an issue. Is there any way to still push the paramters from the main to the base component if the sub assembly is a substitute level of detail? Or is there a better way to fix this problem?
Thanks.
