is there a way to show the user symbols in the toolbar?
Solved by wayne.brill. Go to Solution.
Can you add more detail about what you are trying to do? If possible upload a screenshot and maybe a code example that is not working that will help explain.
this is just an idea.
im just wondering if its possible to create a user sketch symbol and have like a library of it and be able to show all the user symbol in the toolbar, so user can pick from that to insert.
all that using vba.
hoping its possible...
I believe this is possible. As a quick test insert a user form to a VBA project and add a image conrol to the form. The image control has a picture property. You can set this property to an image file such as a .bmp or jpg. You can create the image file by taking a screenshot of the sketchedsymbol. The image control has a click event. When you show the form and click on the image you can run code that inserts the SketchSymbol.
The more complex part of doing this would be getting the coordinates to place the sketchedsymbol. (also the rotation). This sample in the help file creates a SketchedSymbolDefinition and adds a SketchedSymbol to the active sheet. The coordinates and rotation are hard coded. You could have a button on the form that gets the coordinates to use. To create a drag image you could use InteractionEvents.
You could also create an Add-In that adds a ribbon panel that has pictures and inserts them when they are clicked. The StandardIcon and LargeIcon are properties of the ButtonDefinition that would be added to the ribbon.
This blog post has an example of creating an Add-In. (Lab 10)
http://modthemachine.typepad.com/my_weblog/2012/02/inventor-api-labs-step-by-step.html
Also see the "Creating an Inventor Add-In" topic in the help file. Here on my system:
"C:\Program Files\Autodesk\Inventor 2014\Local Help\admapi_18_0.chm"
I am using Visual Studiio Pro. This discussion thread discusses using VS 2012 Express.
