split all intersecting surfaces
12 REPLIES 12
Message 1 of 13
859 Views, 12 Replies
is there a command or workflow to split all intersecting surfaces?  currently we build surface models and split manually or open in autocad, explode, overkill, breakall, then export the lines for rebuilding in an FE package.
Ideally we would like to export straight from inventor with one hit
See attached part, i would like to do the 5 splits below the EOP marker automatically
12 REPLIES 12
Message 2 of 13
xiaodong_liang
Hope the following code is what you are looking for.
Sub Split()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oDoc.ComponentDefinition
'    Dim oPl As WorkPlane
'    Set oPl = oCompDef.WorkPlanes("XZ Plane")
    'arguments
    Dim oWS1 As WorkSurface
    Set oWS1 = oCompDef.WorkSurfaces(1)
    Dim oObjColl As ObjectCollection
    Set oObjColl = ThisApplication.TransientObjects.CreateObjectCollection()
     Dim oSurface As SurfaceBody 'WorkSurface
      Set oSurface = oCompDef.WorkSurfaces.Item(2).SurfaceBodies(1)
        Dim oFace As Face
        For Each oFace In oSurface.Faces
            oObjColl.Add oFace
        Next
    Dim oSplit As SplitFeature
    Set oSplit = oCompDef.Features.SplitFeatures.SplitFaces(oWS1, False, oObjColl)
End Sub
Message 3 of 13
in reply to: xiaodong_liang
thanks for the reply, i have been on leave...  i will try it today hopefully
Message 4 of 13
I tried it and it only does (split 2) if you pull down the EOP marker.
I want to split every intersecting surface on a model that may have 1000 surfaces.
I gues it would run something like,
List all visible surfaces
split surface 1 with surface 2
split surface 1 with surface 3
split surface 1 with surface xxx
split 2 with 3
2 with 4
etc etc
Message 5 of 13
this would be so useful...  i cant see any software that does it...
Message 6 of 13
Vladimir.Ananyev
Try this demo on your model.  This code uses the idea of Xiaodong in two loops.
Sub Split_2()
  'The 1st work surface
  Set oWS1 = oCompDef.WorkSurfaces.Item(1)
  Dim N As Integer
  N = oCompDef.WorkSurfaces.count
  Dim i As Integer
  Dim oFace As Face
  For i = 2 To N
     Call oObjColl.Clear
     Set oSurface = oCompDef.WorkSurfaces.Item(i).SurfaceBodies(1)
         oObjColl.Add oFace
     Next
     Set oSplit = oCompDef.Features.SplitFeatures _
   Next i
  For i = 2 To N
     Call oObjColl.Clear
     For Each oFace In oWS1.SurfaceBodies(1).Faces
         oObjColl.Add oFace
     Next
           .SplitFaces(oSurface, False, oObjColl)
  Next i
  Beep
End Sub
I hope that the idea is clear, and you can customize this code to suit your needs.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 7 of 13
in reply to: Vladimir.Ananyev
This seems to work perfectly on the test model and Ive added a few more surfaces  that also seem to work, dropped into femap and meshed instantly with no problems...
thankyou very much, I am going to try it on a proper model now and let you know the results, this could save me a lot of time
Message 8 of 13
is there a way to just list and act on the visible surfaces?
Message 9 of 13
Vladimir.Ananyev
No problem.
You may exclude any work surface if its property Visible returns False.
Vladimir Ananyev
Message 10 of 13
is there a maximum number of surfaces this can handle? it counts all of the surfaces correctly but doesnt split them all over a certain number.  i tried on a real model then came back and tested against the attached part...
also it would be good if it automatically deleted failed splits that dont intersect
Message 11 of 13
ok, I understand a bit better, it is only splitting based on the worksurface, i need it to split every surface that intersects another so I am missing any surfaces off this plane...
Message 12 of 13
This has risen again... can anyone think of an easy way to do this? ideally automated
Message 13 of 13
xiaodong_liang
Hi
