Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
select 1 occurrence from multiple
8 REPLIES 8
Message 1 of 9
Burnit87
540 Views, 8 Replies
i'm need some help with selecting 1 part from multi select
im building a dxf generator and i can select an entire assembly and it just fishes out the sheet metal, but when i select the same part a couple of times it wil do it  multiple times and thats just a wast of time
so what im basicly looking for is the code that does the opposite of select all occurrences,
so i got a bunch selected and i just want 1 of each parts so part1 1 time , part2 1 time and so on...
tried the ComponentOccurrencesEnumerator, but cant get it to work in a selectset ( so i can count how many times i selected part1)
any ideas someone?
would me very appreciated!!
thanks in advance
Björn
BP
8 REPLIES 8
Message 2 of 9
mrattray
in reply to: Burnit87
I'm not sure how to solve your issue, but I believe there is a free add-in available on the app exchange to accomplish this already.
Mike (not Matt) Rattray
Message 3 of 9
alyssaweaver
in reply to: mrattray
I'm not positive this is what you want, but check this out. It allows you to select some occurences rather than all.
http://designandmotion.net/autodesk/replace-some-components-in-inventor-2014/
Best Wishes,
Ali
"It's a screwdriver, not a water pistol! What are you gonna do? Construct a cabinet at them?!"
Message 4 of 9
Burnit87
in reply to: alyssaweaver
ok i tell step by step what i want it to do
- first ill set my selection to part priority
- then select complete assembly
- check for double selection
- take sheet metal parts
- run t he dxf genereator for
and the double selection part is where im having troubles, cause if a part is selected 6 times the dxf generator will unfold it 6 times and export it 6 times, wich costs a lot of time, if you got muliple  patterns, and i dont want to hand pick every component.
so basicly i want it to check if a part is being selected multiple occurrences and then deselect all but one.
BP
Message 5 of 9
Burnit87
this is how far i've got, it works sort of but it now keeps de-selecting everything that had more then one selection, im looking for a way to update my selectset
'check if the same part is selected multiple times
ForEach prtDocOcc As ComponentOccurrence In SelSet
ForEach prtDocOcc2 As ComponentOccurrence In SelSet
If prtDocOcc.Definition.Document.fullfileName = prtDocOcc2.Definition.Document.fullfileName Then
If prtDocOcc.Name <> prtDocOcc2.Name Then
SelSet.Remove(prtDocOcc2)
'update selectset or it will de-selecting everything that had more then 1 occ selected
EndIf
EndIf
Next
Next
BP
Message 6 of 9
alyssaweaver
The code on that link I sent you should allow you to select the single occurrence from the get go. Is that not acceptable for what you want to do?
Best Wishes,
Ali
Message 7 of 9
Burnit87
**** missed it,
been searching al day for a solution but i fixed it
thank you a whole lot
redo:
ForEach prtDocOcc AsComponentOccurrenceIn SelSet
ForEach prtDocOcc2 AsComponentOccurrenceIn SelSet
GoTo redo
EndIf
EndIf
Next
Next
BP
Message 8 of 9
Burnit87
ran into anthoter problem, when you have  multiple subassemblies you'll need an extra if
redo:
GoTo redo
ElseIf prtDocOcc.Name = prtDocOcc2.Name Then
Try
If prtDocOcc.ParentOccurrence.Name <> prtDocOcc2.ParentOccurrence.Name Then
GoTo redo
EndIf
Catch ex AsException
EndTry
EndIf
EndIf
Next
Next
BP
Message 9 of 9
Burnit87
and worked out another solution for big assemblies, cause the current loop takes 3 to 4 times as long
Dim firstLoopCounter AsInteger = 1
Dim secondLoopCounter AsInteger = 1
Dim toRemove AsNewCollection
secondLoopCounter = 1
If secondLoopCounter > firstLoopCounter Then
toRemove.Add(prtDocOcc2)
Try
EndIf
EndTry
EndIf
EndIf
EndIf
secondLoopCounter = secondLoopCounter + 1
Next
firstLoopCounter = firstLoopCounter + 1
Next
ForEach prtDocToRemove AsComponentOccurrenceIn toRemove
SelSet.Remove(prtDocToRemove)
Next
BP
