I have a program which creates a new part. It works, but
If I click on the brower I can go into Model mode, and the No Browser option disappears.
And I can simply maximise the window using the maximise icon in the part Window.
But how do I do these programatically? And why is there no Model browser by default?
This is C++ COM from an external EXE.
Solved by philippe.leefsma. Go to Solution.
Can you provide the sample code, so I can test in the same conditions than you do?
Philippe.
I'll try to simplify my code to get it into a single file to reproduce the error.
I've found the call which has the effect of putting the part window in normal mode and setting the browser to "No Browser"
HRESULT CreateNewPartDoc (const CComPtr<Application>& pInvApp, CComPtr<PartDocument>& pPartDocument) { // Get part document template _bstr_t templateFilename = pInvApp->MethodGetTemplateFile(kPartDocumentObject, // get the PART template file kDefaultSystemOfMeasure, kDefault_DraftingStandard, vtMissing); // Get the list of Documents CComPtr<Documents> pDocs; HRESULT hr = pInvApp->get_Documents(&pDocs); if (FAILED(hr)) { return ReturnAndShowCOMError (hr,L"CreateNewPartDoc, get document list failed\n") ; } const long ikNumDocs = pDocs->GetCount() ; wprintf (L"There are %d documents open in Inventor\n",ikNumDocs) ; // Create a new part document CComPtr<Document> pDocument; hr = pDocs->Add(kPartDocumentObject, templateFilename, VARIANT_TRUE, // create visible &pDocument); // return value if (FAILED(hr)) { return ReturnAndShowCOMError (hr,L"CreateNewPartDoc, Add part failed ") ; } // convert generic document to partdocument
// THIS call causes the "problem" hr = pDocument->QueryInterface(DIID_PartDocument, (void**)&pPartDocument); if (FAILED(hr)) { return ReturnAndShowCOMError (hr,L"CreateNewPartDoc, get part document failed ") ; } return (hr) ; }
On that call to QueryInterface(DIID_PartDocument,... the browser disappears, though you can go to the part manually. Inventor 13. See the attached image
I am using this code and it works fine:
HRESULT CreateNewPartDoc( CComPtr<Application> pInventorApp, CComPtr<PartDocument> &pPartDoc) { HRESULT hr = S_OK; CComVariant pSubDocType; CComBSTR sTemplate; hr = pInventorApp->GetTemplateFile( kPartDocumentObject, kDefaultSystemOfMeasure, kDefault_DraftingStandard, pSubDocType, &sTemplate); if(hr != S_OK) { return hr; } CComPtr<Document> pDoc; hr = pInventorApp->Documents->Add( kPartDocumentObject, sTemplate, VARIANT_TRUE, &pDoc); if(hr != S_OK) { return hr; } pPartDoc = CComQIPtr<PartDocument>(pDoc); return hr; }
Philippe.
Your solution is much cleaner than mine, and works as you say. But now mine does too, I must have been doing something stupid before the call.
Anyway thanks, and I'll use your shorter clearer solution.
