Inventor Customization
j.vanderheijden
Message 1 of 2 (216 Views)
place iLogic Component
216 Views, 1 Replies
12-28-2012 09:22 AM
Is it possible to skip the small preview window and the parameters display when i place an iLogic component white the command Place iLogic Component.
Mvg Jos
Your drawings are only as good as the symbols that complete them...
ADN Support Specialist
adam.nagy
Message 2 of 2 (166 Views)
Re: place iLogic Component
01-15-2013 08:38 AM in reply to: j.vanderheijden
Happy New Year!
If you don't want the preview window to appear, you don't want the parameters dialog to appear, then the only functionality left is the copying of the file that you want to place.
You could do that using Windows API or e.g. the ThisApplication.FileManager object
Then you could just start the component placement command ("Place") of Inventor with the copied part/assembly like shown in this devblog post: http://adndevblog.typepad.com/manufacturing/2013/01/provide-command-parameters-using-postprivateeven...
In iLogic it would look like this:
Dim cm As CommandManager
cm = ThisApplication.CommandManager
cm.PostPrivateEvent(
	PrivateEventTypeEnum.kFileNameEvent,
	"C:\Users\Administrator\Documents\Inventor\TempProject\part - copy.ipt")
Dim cd As ControlDefinition
cd = cm.ControlDefinitions("AssemblyPlaceComponentCmd")
cd.Execute
I hope this helps.
Cheers,
Adam Nagy
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
