open a pdf after exporting idw to PDF
3 REPLIES 3
399 Views, 3 Replies
Hi!
I'm using the PublishPDf sample code to export IDW's when we do a reivsion of a drawing, and it works fine, but I would like the PDF to "pop up" after I have made it (as it is doing if I print it to PDF995 as is our currentmethod). I wonder if theres an easy method to do this. My best try so far is to add the following code at the end:
Dim oWord As Word.Document '.Application
'On Error Resume Next
Set oWord = CreateObject("Word.Document")
oWord.FollowHyperlink Address:=oDataMedium.filename, NewWindow:=True
oWord.Close (wdDoNotSaveChanges)
Set oWord = Nothing
,but tI wondered if there was a more straightforward method
Thanx
Ulf
3 REPLIES 3
Hi Ulf
Add the lines at the end of your code.
The varialble ProgramPath is added to ensure language differens in the name of this folder in Windows, if you use Adobe Reader 10 just change the value from 9.0 to 10.0 to get the correct path of the Adobe Reader
/Patrick
Dim shellResult As Double
Dim ProgramFilesPath As String
ProgramFilesPath = Environ("PROGRAMFILES")
shellResult = Shell(ProgramFilesPath & "\Adobe\Reader 9.0\Reader\AcroRd32.exe" & " " & oDataMedium.FileName, vbNormalFocus)
If shellResult = 0 Then MsgBox "Launche of Adobe Reader failed.", vbCritical + vbOKOnly
Thanks a lot Patrick!
That worked great.
... but while I waited for an answer I found another solution which I tried out as well, and it might sometimes be more convenient, since I'm not sure which version of Acrobat Reader our designers use, or if they use an entire different program. If you or anyone else is interested, heres the code:
In the declarations part of the module (the beginning)
Public Declare Function ShellExecute _
Lib "shell32.dll" _
Alias "ShellExecuteA" ( _
ByVal hwnd As Long, _
ByVal lpOperation As String, _
ByVal lpFile As String, _
ByVal lpParameters As String, _
ByVal lpDirectory As String, _
ByVal nShowCmd As Long) _
As Long
and in the code:
Dim r As Long
r = ShellExecute(0, "open", oDataMedium.filename, 0, 0, 1)
If r < 32 Then MsgBox ("Couldn't start your PDF-reader")
the code was found at:
http://support.microsoft.com/kb/224816
1-0 to you, thanks for sharing.
/Patrick
