Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
Solved by NachitoMax. Go to Solution.
If you're using the templates that come with inventor, then it's a matter of making sure your paths are right in visual studio and hitting the build button.
That generates the dll and addin file.
The addin file is a text file that goes under c:\program data\autodesk\inventor 2013\addins (or something close to that path as it's from memory)
The addin file also has a line telling inventor where the dll you created resides, for example C:\MyAddins. Put your dll in that folder and on next run, Inventor will load the addin file see it's pointing to MyAddins and then load the dll file specified.
Nacho
Hi
i found the wizard installer (which i apparently missed when i looked before lol). i tried to install it but it says that it cant find visual studio. i have visual studio express. Would you by chance be able to send the template file that gets installed so that i can use that?
Nigel
Nacho
Hi
i have the file extracted and i am using the same inventor addin. however, when i build my app as a class into a dll, nothing gets registered into the 'Addins' part of inventor as documentation and videos suggest. therefore, what could i be doing wrong?
This highlighted file
was NOT a part of my original Inventor project template. i copied it into my file but couldnt reference it as i got an error. Can anyone give me a bit of advice please?
Nigel
Nacho
Hi
the text inside the addin is as follows-
<Addin Type="Standard"> <!--Created for Autodesk Inventor Version 17.0--> <ClassId>{$guid1$}</ClassId> <ClientId>{$guid1$}</ClientId> <DisplayName>$safeprojectname$</DisplayName> <Description>$safeprojectname$</Description> <Assembly>$safeprojectname$.dll</Assembly> <LoadOnStartUp>1</LoadOnStartUp> <UserUnloadable>1</UserUnloadable> <Hidden>0</Hidden> <SupportedSoftwareVersionGreaterThan>16..</SupportedSoftwareVersionGreaterThan> <DataVersion>1</DataVersion> <UserInterfaceVersion>1</UserInterfaceVersion> </Addin>
what line do you refer to when you say this?-
QUOTE
Nacho
Hi
i have figured this out now 🙂
Nacho
