Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
name to show in vba code
7 REPLIES 7
Message 1 of 8
akosi
501 Views, 7 Replies
how to show in the message box the assembly name or part name in the model browser without selecting it using vba?
thanks
7 REPLIES 7
Message 2 of 8
jdkriek
in reply to: akosi
Several ways to do this, just depends on what you are using it for
Public Sub NameThat()
Dim oAssDoc As AssemblyDocument
Set oAssDoc = ThisApplication.ActiveDocument
Dim oAssDef As AssemblyComponentDefinition
Set oAssDef = oAssDoc.ComponentDefinition
Dim oOccurrence As ComponentOccurrence
	For Each oOccurrence In oAssDef.Occurrences
		sName = Split(oOccurrence.Name, ":")
		MsgBox (sName(0) & " in " & oAssDoc.DisplayName)
	Next
End Sub
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 3 of 8
akosi
in reply to: jdkriek
thanks!!!Smiley Happy
Message 4 of 8
jdkriek
in reply to: akosi
You're welcome 😉
Jonathan D. Kriek
Message 5 of 8
akosi
quick question >>> jd
ive finished my macro , tested it and works perfectly.
but after ive added it to our default vba project and after making a button, and accessing the macro from the button,
it stop working !  sometimes it works but it process so slow like its frozen and i have to hit esc to exit.
what do i have to check to fix this.
Message 6 of 8
jdkriek
in reply to: akosi
Msgboxs halt all processes until it is dismissed, so if you have a lot of parts in your assembly it might be hanging. I usually write the results to a .txt file for large assemblies or just simply use debug.print and watch the "Immediate" window inside the VBA editor.
Jonathan D. Kriek
Message 7 of 8
akosi
i dont understand.
what is it do , if i make it write to a text file or immediate window?
Message 8 of 8
jdkriek
in reply to: akosi
It stops it from hanging usually, again Msgbox stops the program untill you click it.
Jonathan D. Kriek
