First off. I am pretty new at the hole Ilogic stuff.
I want to great a messagebox with the abbility to great multi input text to Ipropeties.
I have no problems with the input to ipropeties but how do I great more input lines in the same messagebox sow that it is possible to type in "revision number" "Description" and other ipropeties from the same messagebox?
Solved by MariaManuela. Go to Solution.
You already create a iLogic Form?
You can simple drag to a new Form the file iProperties in order to fill the fieds.
