Hi guys,
I have an assembly that contains a part and a hole feature (the hole feature is at the assembly level). Using the api, I'm trying to get the hole location relative to the part's coordinate system in a without using the holeplacementdefinition.distance property, this way I can get the hole location regardless of the way it was defined. Any help would be greatly appreciated.
Dominik
Solved by ekinsb. Go to Solution.
Below is some code that I believe will do what you want. I've tried to comment it to explain what's going on.
Public Sub AssemblyHoleFeatureInPartSpace()
Dim asmDoc As AssemblyDocument
Set asmDoc = ThisApplication.ActiveDocument
Dim hole As HoleFeature
Set hole = ThisApplication.CommandManager.Pick( _
kAssemblyFeatureFilter, _
"Select a hole feature.")
' A single hole feature can define multiple actual holes
' in a part and the position of the holes can be defined
' in different ways, i.e. at sketch points, distance from
' an edges, concentric to a circle, etc. The
' HoleCenterPoints property returns the coordinate point
' for each physical hole created by the hole feature. The
' code below uses that to determine the hole position and
' then gets a cylinder from the hole to determine the
' direction.
Dim holeCenter As Object
For Each holeCenter In hole.HoleCenterPoints
' Center points can be returned as a sketch point when
' the hole was created using a sketch point, or a
' coordinate for other placement types.
Dim holePosition As Point
If TypeOf holeCenter Is SketchPoint Then
Dim holeSketchPoint As SketchPoint
Set holeSketchPoint = holeCenter
Set holePosition = holeSketchPoint.Geometry3d
Else
Set holePosition = holeCenter
End If
' Iterate through the occurrences the hole affects.
Dim occ As ComponentOccurrence
For Each occ In hole.Participants
' Get the transform from the occurrence.
Dim occMatrix As Matrix
Set occMatrix = occ.Transformation
' Invert the matrix to get an assembly to
' occurrence transform.
occMatrix.Invert
' Transform the hole point into occurrence space.
Dim newPoint As Point
Set newPoint = holePosition.Copy
Call newPoint.TransformBy(occMatrix)
' Display the coordinates.
Debug.Print "Position in assembly space"
Debug.Print (" " & hole.name & " position in " _
& occ.name & " is " & _
Format(holePosition.X, "0.000000") _
& "," & _
Format(holePosition.Y, "0.000000") _
& "," & _
Format(holePosition.Z, "0.000000"))
Debug.Print "Position in part space"
Debug.Print (" " & hole.name & " position in " & _
Format(newPoint.X, "0.000000") _
& "," & _
Format(newPoint.Y, "0.000000") _
& "," & _
Format(newPoint.Z, "0.000000"))
Next
Next
End Sub
