Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
lumpdefinition
7 REPLIES 7
Message 1 of 8
humbertogo
532 Views, 7 Replies
lumpdefinition
I have a part with a multiple lumpdefinition
and I trying to count all lump in the activeDocument
Does anyone know how do it?
Thanks in advance.
7 REPLIES 7
Message 2 of 8
Hi
There is no way to retrieve the lumps once your surface body has been created, the LumpDefinition object is used only has a transient entity when your are generating a surface body using TransientBRep.CreateSurfaceBodyDefinition.
You can access the various surface bodies if you are working in a multi-body part, each body can have one or several face shells, but you do not have access to lumps. What are you trying to achieve anyway with counting the lumps? I see no point doing that...
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
Thanks any way
<What are you trying to achieve anyway with counting the lumps?>
I try to recognize this kind of parts
Message 4 of 8
Which kind of parts? Multi-body? Multi face shell?
There is no such kind of part as multi lumps, so it's unlikely you can achieve this ...
Philippe Leefsma
Message 5 of 8
A part with one solid bodie and multiple lump
Message 6 of 8
Once again: there is no such thing as lumps once the surface body has been created, lumps are only transient entities used when creating a solid body using the API.
Your part simply contains multiple face shells, 272 in the example you provided.
I hope it helps.
Philippe Leefsma
Message 7 of 8
I'll try the multiple face shells
Message 8 of 8
humbertogo
in reply to: humbertogo
Thanks again
I done
oPartDocument.ComponentDefinition.SurfaceBodies.Item(1).FaceShells.Count
