hi
i wrote a code that hide the object from assembly by selection.
in this case i filtered it using "kSketchDimConstraintFilter".
from the browser-
1. assy
1.1 part
1.1.1 sketch - this has a square and 2 dimensions
it hides the chosen dimension (one dim from 1.1.1 sketch)
the browser still shows visible 1.1.1 sketch - thats fine
it works perfectly.
now my problem is -
how to bring back or make visible the object again.(one dim from 1.1.1 sketch)
I'm not sure I understand the issue. So you are using Pick() with kSketchDimConstraintFilter?
If you know what you hide then you should be able to make it visible again right?
Could you show the code in question?
Cheers,
