Inventor Customization
Valued Contributor
wowens63
Message 1 of 10 (327 Views)
ipt to dxf
327 Views, 9 Replies
08-27-2013 07:02 AM
using Inventor 2012 API
Is it possible to export a ipt file to a dxf file? (no im not talking about the flat pattern) I mean any ipt file sheet metal or not.
wade
ADN Support Specialist
Vladimir.Ananyev
Message 2 of 10 (300 Views)
Re: ipt to dxf
08-28-2013 02:46 AM in reply to: wowens63
Could you please test the Export to DXF API Sample from Inventor API help? It can be found in Translators section.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Valued Contributor
wowens63
Message 3 of 10 (288 Views)
Re: ipt to dxf
08-28-2013 05:32 AM in reply to: wowens63
that was the first thing i tried but unfortunately there code does not make a valid dxf file..
error from autocad when opening the dxf file..
Error in drawing header on line 1.
C:\tempdxfout.dxf is not valid DXF file
Invalid or incomplete DXF input -- drawing discarded
thanks anyway
Vladimir.Ananyev
Message 4 of 10 (281 Views)
Re: ipt to dxf
08-28-2013 06:11 AM in reply to: wowens63
If you upload 1) Inventor file,  2) VBA test code and 3) produced by this code dxf file, then we have a chance to investigate this problem.
Vladimir Ananyev
Valued Contributor
wowens63
Message 5 of 10 (273 Views)
Re: ipt to dxf
08-28-2013 07:54 AM in reply to: wowens63
here is all items, but the code is vb.net with visual studio 2010
Valued Contributor
wowens63
Message 6 of 10 (270 Views)
Re: ipt to dxf
08-28-2013 08:00 AM in reply to: Vladimir.Ananyev
here is a part.ipt file with the VBA code..the code was copied pasted from the Inventor help file..
Vladimir.Ananyev
Message 7 of 10 (240 Views)
Re: ipt to dxf
08-29-2013 12:49 AM in reply to: wowens63
Have you tested your workflow in UI?
You should create drawing from your part and then run translator to produce DXF file.
Cheers,
Vladimir Ananyev
Valued Contributor
wowens63
Message 8 of 10 (228 Views)
Re: ipt to dxf
08-29-2013 05:18 AM in reply to: wowens63
ok so I need to create a drawing from the part.ipt file first then convert to DXF correct? in other words you can not create a DXF file from a Part.ipt file directly
ekinsb
Message 9 of 10 (220 Views)
Re: ipt to dxf
08-29-2013 02:36 PM in reply to: wowens63
You're correct, Inventor does not support writing 3D models to DXF.  You can write out 2D data, sketches and drawings, as DXF.
Brian Ekins
Valued Contributor
wowens63
Message 10 of 10 (210 Views)
Re: ipt to dxf
08-30-2013 05:30 AM in reply to: wowens63
thank you.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
