Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
ilogic rule to make all my number in odd number
13 REPLIES 13
Message 1 of 14
ChristinaForest
1367 Views, 13 Replies
I dont no in english if odd number is the right word but i want to make all my number to 1, 3, 5, 7, 9, etc,....
Thanks for your help 🙂
13 REPLIES 13
Message 2 of 14
mehatfie
in reply to: ChristinaForest
Hi sergelachance,
I'm not exactly sure what numbers you are trying to change?
And yes, Odd Numbers is the correct way of saying this.
Regards
Mitch
Message 3 of 14
ChristinaForest
in reply to: mehatfie
Thanks Mitch for your reply 🙂
Do you have a exemple of rule?
Message 4 of 14
mehatfie
Hi sergelachance,
Please use a translator to understand, or what language do you speak?
I am asking a question about what numbers you are making odd.
Regards
Mitch
Message 5 of 14
Sorry for my horrible english, i'm french Canadian 🙂
I just want  to change with ilogic when my parameters number is even same to 0,2,4,6,8,etc,... change to odd number same to 1,3,5,7,9,etc,.... what is a right rule for that???
Thanks again!
Message 6 of 14
mehatfie
Hi sergelachance,
This is a simple rule that will check for what you have asked. I'm not sure of your true application, but for a single parameter this should work.
The code is dividing the parameter by 2, if the remainder is not 0 (ie. it is not divisible by 2 into a whole number), the code will add 1 to the parameter.
------------- Code ----------------------
If (Parameter("PARAMETER_NAME_HERE") Mod 2) <> 0 Then
     Parameter("PARAMETER_NAME_HERE") = Parameter("PARAMETER_NAME_HERE") + 1
End If
Regards
Mitch
Let me know if it helps.... Kudos if it works!!!
Message 7 of 14
ChristinaForest
Hi Mitch 🙂
the rule work but for what add 1 if the parameter is not dividing by 2???
Message 8 of 14
mehatfie
Sergelachance,
I'm sorry, for some reason I was thinking the opposite and you wanted even numbers.... I have no idea why I was thinking this.
Change the code as follows:
Replace: "<>"
With: "="
This will instead mean, if the number DOES divide by 0 and has NO remainder (ie. an even number) then add 1 (to make it odd).
Regards
Mitch
Let me know if it helps... Kudos if it works!!!
Message 9 of 14
Thank you very much for all Mitch!
i try that later 🙂
Message 10 of 14
i try but same probleme 😞
Message 11 of 14
mehatfie
Hi sergelachance,
I'm not quite sure I understnad what the problem is. The code I provided adds 1 to an even number in order to make it odd. You could also MINUS 1 if you'd like in order to achieve an odd number as well.
What confuses me with your code is that you have 2 different parameters being used.
Why is it:
("TROUSTAB" Mod 2) = 0 Then
     "QTETROUSTAB" = "TROUSTAB" + 1
Shouldn't it  be:
     "TROUSTAB" = "TROUSTAB" + 1
Regards
Mitch
Message 12 of 14
ChristinaForest
Hi Mitch, i try your new rule but dont work again 😞
Message 13 of 14
mehatfie
Sergelachance,
That was NOT a new rule,  you must keep the OLD rule but replace the parameter name
If (Parameter("TROUSTAB") Mod 2) = 0 Then
     Parameter("TROUSTAB") = Parameter("TROUSTAB") + 1
End If
Message 14 of 14
ChristinaForest
OK, Thank you very much Mitch for your time 🙂
