ilogic rule for each part in the assembly to change partt paramenter
6 REPLIES 6
9633 Views, 6 Replies
I`m looking for the iLogic code that can change one parameter (user defined) for each (ipt) part in assembly (iam)
The one below doesn`t work. Any help is appreciated.
Sub Main
  Dim oApp As Inventor.Application =  ThisApplication
  Dim oAssy As Inventor.AssemblyDocument = oApp.ActiveDocument
  For Each oSubDoc as Inventor.Document In oAssy.AllReferencedDocuments
  On Error Resume Next
   Parameter(oSubDoc, "FH") = 15.26
  Next
   End Sub
6 REPLIES 6
YuhanZhang
I think you can use it like below:
Parameter("Part1:1", "d0") = 1.2
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
in reply to: YuhanZhang
Rocky,
That what I had in my code :
I thought it suppose to take every ipt in my iam as oSubDoc find the FH parameter and change it to 15.26.
Am I doing something wrong?
Curtis_Waguespack
Hi achmidt,
Here are two examples that will work. The first looks at the occurences by name the second looks at the actual files by file name:
' set a reference to the assembly component definintion.
' This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
'check for and skip virtual components
'(in case a virtual component trips things up)
If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
Parameter.Quiet = True
Parameter(oOccurrence.Name, "FH") = 15.26
InventorVb.DocumentUpdate()
Else
End If
Next
'Define the open document
Dim openDoc As Document
openDoc = ThisDoc.Document
'Look at all of the files referenced in the open document
Dim docFile As Document
For Each docFile In openDoc.AllReferencedDocuments
'format  file name
Dim FNamePos As Long
FNamePos = InStrRev(docFile.FullFileName, "\", -1)
Dim docFName As String
docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
Parameter(docFName, "FH") = 15.26
Next
 I hope this helps.
Curtis
in reply to: Curtis_Waguespack
Curtis,
Thanks a lot, that what I was looking for!
Hi Curtis 🙂
It's possible to put a try and catch in the rule to verify if parameter exist???
Thnaks for your help 🙂
is it possible to re write it to make all part numbers in sub assemblies and parts equal to filename minus extensions.
i've tried several different ilogic rules, posted different places, and none seems work, or i get a error.
i want the rule to run on assembly level, and not embeded in the part template.
