I am doing a project which is dependent on iProperties and is working well. However in one typical case i am required to extract data from IDW File BOM.
Is it possible to do so and if yes and reference is available.
rgds
You may use the following object’s relationships:
DrawingDocument => DrawingBOMs => DrawingBOM => DrawingBOMColumns and DrawingBOMRows collections and DocumentDescriptor object.
DrawingBOMRow => DrawingBOMCell => Value
DrawingBOMRow => BOMRow Property => (ItemNumber, ItemQuantity, TotalQuantity, etc.)
Hi Amitk
Did you find a solution to this ? I am working on the same task !
