Inventor Customization
Valued Mentor
Message 1 of 2 (102 Views)
iMate conflict checking
102 Views, 1 Replies
11-22-2012 03:20 AM
How to ietrate thru assembly documet and find out any imate results are conflict in the Assembly document?
Valued Mentor
Message 2 of 2 (92 Views)
Re: iMate conflict checking
11-26-2012 10:12 AM in reply to: saseendrankombath
Solved !
 oAssyDoc = m_inventorApplication.ActiveDocument
        oAssyCompDef = oAssyDoc.ComponentDefinition
        Dim oConstraint As AssemblyConstraint
        Dim oObjectCol As ObjectCollection
        oObjectCol = m_inventorApplication.TransientObjects.CreateObjectCollection
        For Each oConstraint In oAssyCompDef.Constraints
            If oConstraint.HealthStatus = HealthStatusEnum.kInconsistentHealth Then
                oObjectCol.Add(oConstraint)
            End If
        Next
        If oObjectCol.Count <> 0 Then
            MsgBox(oObjectCol.Count & " - Inconsistent Constraints found in this Assembly, Please Correct it before using Bolt Insert")
            Exit Sub
        End If
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
