H all
I need to switch a layer in a drawing on or off using Ilogic. I know the layer name etc but can't find anything in the help.
Can anyone help please.
i have this much:
If iProperties.Value("Status", "Design State") = 3 Then ThisDrawing.Document.StylesManager.Layers("Banner")= False Else ThisDrawing.Document.StylesManager.Layers("Banner")= True End If
Thanks in advance
Solved by waynefisher. Go to Solution.
how do I program the iLogic, that runs automatic by create a new drawing?
Hi @SebastianPappe ,
You can use an event trigger to do this:
I hope this helps.
Curtis
