Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic string
3 REPLIES 3
2531 Views, 3 Replies
iLogic string
I previously posted this in the general section, but was refered here, so sorry for the double post.
http://forums.autodesk.com/t5/Inventor-General/Folder-Name-for-dwg/m-p/4771057/highlight/false#M4953...
I'm looking for a way to reference a folder name that contains my part / assembly.  I want to use that folder name in the title block of my drawing.
For Example:
server\drawings\customer 1\machineA\replacement part01.ipt
server\drawings\customer 2\machine04\replacement assembly.iam
I want to be able to 'extract' the customer 1 or customer 2 name from the file path.
I've searched around for awhile now, but I can't find a solution.
I'm new to using iLogic and coding, but I've stumbled through this bit of code:
'My Ilogic
Dim Flp As String
'Set Flp to file path
Flp = ThisDoc.Path
'set iproperties for Company---
iProperties.Value("Summary", "Company")= Flp
It gets the file path and sets that equal to the iProperty-Company.  Is there some way I can only take part of the filename string?
Thanks for your help,
-Ryan
3 REPLIES 3
Ktomberlin
"server\drawings\customer 1\machineA\replacement part01.ipt"
You can do something like.
Flpath=(Mid(ThisDoc.WorkspacePath(),16))
Flpdir="\"
Folderpos=InStr(Flpath, Flpdir)
oFolder=Folderpos-1
Flp=(Left(Flpath,oFolder))
 The first line should get rid of the "server\drawings\" Then you can find the position of the next "\". then use that to get the customer only.
in reply to: Ktomberlin
Dim Flp As String
Dim Flpdir As String
'Set Flp To file path
Flp = ThisDoc.Path
'removes server name and drawings directory
Flpath=(Mid(Flp,13))
'Flpath=(Mid(ThisDoc.WorkspacePath(),16))
Flpdir="\"
oFolder=Folderpos-1
'original:  oFolder=Folderpos-1
iLogicVb.UpdateWhenDone = True
 I had to modify it a bit because I kept getting the error that length couldn't equal zero.  I think it was because I said that my structure was:
server\drawings\customer 1 when it's really Z:\drawings\customer1\...
Thank you
Ktomberlin
Sure that path difference would cause that issue.  If this is working for you great.  Your using "Flp = ThisDoc.Path" I would think ThisDoc.WorkspacePath would give a better result.
