Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic rule to change Title Blocks
21 REPLIES 21
Message 1 of 22
SeanFarr
11072 Views, 21 Replies
I can't for some reason get this rule to work, simply want to be able to choose what title block to use.
I created a text parameter with the multi-values: TES ELE and TES EQU
I have 2 title blocks in my template called TES ELE and TES EQU
Here is my code, basically, I want to rule to apply the title block based on the selection, which will be done on a form.
If Title = "TES ELE" Then
ActiveSheet.TitleBlock = "TES ELE"
ElseIf Title = "TES EQU" Then
ActiveSheet.TitleBlock = "TES EQU"
InventorVb.DocumentUpdate()
ThisApplication.ActiveView.Fit
 I have found many threads in this forum and have used their solutions for this rule, but for some reason, my rule will not select the title block and place it in the drawing.
Here is a snap of my set-up and my template file is attached
Thanks!
Sean Farr
Product Designer at TESInc.ca
Inventor Professional 2014-Update 2 - AutoCAD Electrical 2014
Win7-x64 | ASUS P8Z77-V | i7 3770 -3.4 GHz | 32GB RAM |
240GB SSD | nVidia GTX 670 4GB - 320.49
21 REPLIES 21
Message 21 of 22
Ing_Jairo_Meza
in reply to: SeanFarr
Hello SeanFarr, I had the same problem with the prompted entrys and got solve, my question to you is what is the code for the multi-opcion box that you present in this message?
Thanks.
Message 22 of 22
auch wenn es nicht mehr ganz aktuell ist, habe mir ein snip geschrieben, der zwischen englischer und deutscher Vorlage umschaltet:
'switching between predifined title blocks
'If title german, switch to english
If ActiveSheet.TitleBlock="Vorlage Schriftfeld" Then
ActiveSheet.TitleBlock = "template titleblock"
'if title english, switch to german
ElseIf ActiveSheet.TitleBlock="template titleblock" Then
ActiveSheet.TitleBlock = "Vorlage Schriftfeld"
Als Vorlagename ist die Bezeichnung eures Schriftfeldes zu wählen.
Gruß
Frederik
