Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic "copy to buffer code"
9 REPLIES 9
Message 1 of 10
2078 Views, 9 Replies
I`m not sure if this is possible or not.
Is there any way to write a script which copy`s a variable to the buffer? Similar to CTRL-C?
9 REPLIES 9
Message 2 of 10
Hi achmidt,
Anything youj can do in VB.NET you can pretty much do in iLogic.
In VB.NET the clipboard object gives you full access to the windows clipboard.
To use the clipboard in iLogic you need to import the System.Windows.Forms NameSpace.
Once you do that you can simply set text or  on the clipboard object.
Imports System.Windows.Forms
Sub Main
  Dim greeting as string = "Hello World!"
  Clipboard.SetText(greeting)
End sub
Message 3 of 10
For some reason, when I run the rule it says:
Error on Line 3 : Statement is not valid in a namespace.
Any thoughts?
Thanks!
Message 4 of 10
do you have all the Windows Dot.NET Frameworks installed on your PC?
How about the FREE VB.NET 2010 Express programming environment from Microsoft.
Message 5 of 10
Yep, I have VB express 2010 installed and Framework 4.
Message 6 of 10
What version of Inventor are you running?
Message 7 of 10
2012 Prof.
Message 8 of 10
Not sure then.
Did you cut an paste the text from my above post and paste it into your iLogic file?
I've had problems with this forum's messageboard adding hidden characters to the clipboard.
When in doubt I copy and paste into notepad.  Scan for unwanted characters visually then paste it into the iLogic editor.
or
You could manually type in the code displayed.
The snippet works for me.
Message 9 of 10
oh boy, I thought when you use vb.net code you have to check the box Straight VB code. Thats what I did and it didn`t work. When I did uncheck the box - everything worked!!! WTH...
Thanks!
Message 10 of 10
Standing1
Gruff,
the Clipboard works great with iLogic, thank you for the answer on how to use it.
Sub Main
End sub
