Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic form
10 REPLIES 10
Message 1 of 11
JorisSteurs1246
900 Views, 10 Replies
iLogic form
Does anyone knows if it is possible to add the selectionbox for the sheetmetal rule on an ilogic Form ?
Or if not possible, maybe some kinda workaround?
thanks
Joris
Tags (2)
10 REPLIES 10
Message 2 of 11
GosponZ
in reply to: JorisSteurs1246
Maybe tabs, i do have my rules dwg ipt and iam rules on different tabs. Working great. Just my 2 cents
Message 3 of 11
rjay75
If the file is a Sheet Metal file this will fill a Text parameter with the sheetmetal styles. That parameter can then be added to a an iLogic form.
Dim smStyleList As New ArrayList
For Each smStyle As SheetMetalStyle In ThisDoc.Document.ComponentDefinition.SheetMetalStyles
	smStyleList.Add(smStyle.Name)
Next smStyle
MultiValue.List("paramName") = smStyleList
Message 4 of 11
JorisSteurs1246
in reply to: rjay75
Thanks Rjay for this snippet, it works, and I have a slectable list  on my form. Unfortunatly it goes only one way, the part doesn't change when selecting a new SheetStyle. That was actualy my aim. Maybe should have put my question a bit more precise :-).
Tags (2)
Message 5 of 11
rjay75
To go the other way create another rule with this
SheetMetal.SetActiveStyle(paramName)
 When the parameter is update it should set the style.
Message 6 of 11
JorisSteurs1246
in reply to: rjay75
Sorry to say but that last line didn't do the update.
This is what the total iLogic looks like right now.
smStyleList.Add(smStyle.Name)Next smStyle
MultiValue.List("SheetMetalType") = smStyleList
SheetMetal.SetActiveStyle(SheetMetalType)
Message 7 of 11
rjay75
Message 8 of 11
JorisSteurs1246
in reply to: rjay75
Tried this also, even added a document update rule, but the model keep his
thickness stubborn as it is.
Message 9 of 11
rjay75
Hmm. I have gotten to work with two rules. The first rule looks like this.
Next smStyle
The second rule looks like this.
 Each of these are regular rules.
I tested this on Inventor 2014. What version of Inventor are you running?
One thing to note is in the document I tested this it initially appeared not to work but it was because in the sheet metal defaults I didn't have Use Thickness From Rule checked,
Message 10 of 11
JorisSteurs1246
in reply to: rjay75
Yes AI 2014 latest service pack.
Aaaand I got it working now. The problem was that I used external rules,
just a habit of mine to avoid making new templates all the time.
Strange though.... If I made it a normal rule it works fine , I'm going to
save both rules in the file and try if it still works when I trigger the
second rule on parameter change.
Anyhow already big thanks 🙂
Message 11 of 11
Hi all
I want to know if any of you had the experience of an smart form, for example consider a form with woth some parametes, as you can see in the attached picture, my first field, is a drop down menue showing the location of a nozzle, which might be located on top, shell or bottom of a tank, I want to be able to gray out some fields when I choose for example top situation, so, the grayed fields are not accessible and the user cannot write anything in those fields.
