Inventor Customization
Distinguished Contributor
Message 1 of 8 (801 Views)
iLogic form
801 Views, 7 Replies
04-08-2013 03:08 AM
I am working on a simplified form for filling in our iproperties for both the parts and for drawings. Now here is what i come up with, but still have the following issue.
  1. I would like to have a pull-down menu, same as inventor's ipropertie dialog, for the material(s)
  2. I would like to have a pull-down menu for the "Design State" in the form, also just like inventor's ipropertie tab
Then one last question. When I have this, how to I get this form in a way that my other collegues can use them. And is there a way to have my collegue run this from a nice button/macro instead of trigger it from within the ilogic tab (as shown on the left of the attached picture)
thanks,
John
Active Contributor
Message 2 of 8 (760 Views)
Re: iLogic form
04-09-2013 05:16 AM in reply to: buurjongenshon
John,
for the material I property you can use the following which works for me..
iLogicForm.Show("Form Name")
MultiValue.List("Material") = iProperties.Materials
iProperties.Material=Material
Will have to look at Design State later..
Assuming you want this available in all drawings, you would probably have to have a global rule tied to your template, but someone please correct me if I am wrong..not an I logic expert, but stumbling my way through..
Message 3 of 8 (755 Views)
Re: iLogic form
04-09-2013 05:33 AM in reply to: riff62
Thanks for your feedback. I have a global form and that seem to work.
Now I am in that "edit" form part. But how to I get that Material "box" in it and where to I put that code you sent me.. see attachment
Active Contributor
Message 4 of 8 (719 Views)
Re: iLogic form
04-10-2013 04:28 AM in reply to: buurjongenshon
It looks like you have to create a rule..I have one called Materials.
With your form open, click Add Rule, Choose a name for your rule, and enter the code there..In the first line of the code enter the name of your form inside the parentheses.
I havent had time to look at the Design state you are looking for yet..
Message 5 of 8 (712 Views)
Re: iLogic form
04-10-2013 05:16 AM in reply to: buurjongenshon
am sorry, but i have to say it does not work at all. I have a global form and i want a global rule, all so that collegue can use it. I attached my form. But when I make a rule as you ,mentioned I only get errors
Yesterday I created with your code a GLobal Rule and after changing the code to open up the Global Form I have what I wanted. But I needed to make a FX Parameter and a Custom iProperty. But as soon you need to do this it can only be done in for new parts or i everytime need to get this FX and custom property setup.... a drag!
Also when I had it it showing up a pull down list of the materials,  the "funny" thing is that it does not match the material property in inventor's. The list is the same, but whatever I choose from the form or choose from within inventor, they do no match. Pitty realy, since my enthousiasme dropped!
Message 6 of 8 (711 Views)
Re: iLogic form
04-10-2013 05:23 AM in reply to: riff62
Here are some screenshot of what I was telling about...
Member
reaumed
Message 7 of 8 (636 Views)
Re: iLogic form
04-18-2013 02:08 PM in reply to: buurjongenshon
Drop me an email (david.reaume@autodesk.com)  We can connect and I'll help you out.  I am confident we can do whatever you need.
ADN Support Specialist
xiaodong.liang
Message 8 of 8 (612 Views)
Re: iLogic form
04-22-2013 11:26 PM in reply to: buurjongenshon
Hi buurjongenshon,
I am not sure if reaumed has helped you out the requirements. I'd just recommend the other thread in which one peer shared a good sample on how to list materials (in the attachment of message 4).
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/iLogic-Multi-Value-list-from-Materials...
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
