I am working on a simplified form for filling in our iproperties for both the parts and for drawings. Now here is what i come up with, but still have the following issue.
Then one last question. When I have this, how to I get this form in a way that my other collegues can use them. And is there a way to have my collegue run this from a nice button/macro instead of trigger it from within the ilogic tab (as shown on the left of the attached picture)
thanks,
John
John,
for the material I property you can use the following which works for me..
iLogicForm.Show("Form Name")
MultiValue.List("Material") = iProperties.Materials
iProperties.Material=Material
Will have to look at Design State later..
Assuming you want this available in all drawings, you would probably have to have a global rule tied to your template, but someone please correct me if I am wrong..not an I logic expert, but stumbling my way through..
Thanks for your feedback. I have a global form and that seem to work.
Now I am in that "edit" form part. But how to I get that Material "box" in it and where to I put that code you sent me.. see attachment
It looks like you have to create a rule..I have one called Materials.
With your form open, click Add Rule, Choose a name for your rule, and enter the code there..In the first line of the code enter the name of your form inside the parentheses.
I havent had time to look at the Design state you are looking for yet..
am sorry, but i have to say it does not work at all. I have a global form and i want a global rule, all so that collegue can use it. I attached my form. But when I make a rule as you ,mentioned I only get errors
Yesterday I created with your code a GLobal Rule and after changing the code to open up the Global Form I have what I wanted. But I needed to make a FX Parameter and a Custom iProperty. But as soon you need to do this it can only be done in for new parts or i everytime need to get this FX and custom property setup.... a drag!
Also when I had it it showing up a pull down list of the materials, the "funny" thing is that it does not match the material property in inventor's. The list is the same, but whatever I choose from the form or choose from within inventor, they do no match. Pitty realy, since my enthousiasme dropped!
Here are some screenshot of what I was telling about...
Drop me an email (david.reaume@autodesk.com) We can connect and I'll help you out. I am confident we can do whatever you need.
Hi buurjongenshon,
I am not sure if reaumed has helped you out the requirements. I'd just recommend the other thread in which one peer shared a good sample on how to list materials (in the attachment of message 4).
