Any equivalent workflow to this?
Seeing this error
Error on Line 10 : 'SealString_1' is not declared. It may be inaccessible due to its protection level.
Cheers
MES
Dim SealString_1 As String Dim SealString_2 As String Dim SealString_3 As String Dim SealString_4 As String Dim SealString_5 As String Dim SealString_6 As String Dim SealString_7 As String For Each S As String In SealString_1.Split(",") If i = 0 Then name = S If i = 1 Then name = OD If i = 2 Then name = ID If i = 3 Then name = DE If i = 4 Then name = LI i = i + 1 Next S
found split word in snippets!
Dim Separators() As Char = {","} Sentence = SealString_1 Words = Sentence.Split(Separators) i = 0 For Each wrd In Words MessageBox.Show("Word Index #" & i & " = " & Words(i)) i += 1 Next
