Inventor Customization
rmn
Member
rmn
Message 1 of 4 (229 Views)
iLogic error can not find excel file after saving file as a template
229 Views, 3 Replies
12-06-2012 12:02 PM
I'm linking an excel file to an .ipt file with iLogic code determining if the Material type is a certian value it will find the correct material thickness. These file work great when working on them thru Vault but when I "Save As Template" and create this file where our other template files are located (not Vault) this fuction does not work. I have realized that I had to place the a copy of the excel file in the same file folder as the template ipt, but even this does not fix the issue.
I recieve this error:
Error in rule: Material, in document: Part6
'MWW Materials (Inventor).xlsx' could not be found. Check the spelling of the file name, and verify that the file location is correct.
If you are trying to open the file from your list of most recently used files, make sure that the file has not been renamed, moved, or deleted.
It seems completly countintutive that just saving the file as a template file would cause this not to work when all files that are required are located in the same file folder.
Maybe I need a referance to the excel document within the iLogic code. I'm at a loss on this, any suggestions would be welcome.
rmn
Member
rmn
Message 2 of 4 (228 Views)
Re: iLogic error can not find excel file after saving file as a template
12-06-2012 12:04 PM in reply to: rmn
Additional info that did not get attached
ADN Support Specialist
xiaodong.liang
Message 3 of 4 (179 Views)
01-06-2013 10:05 PM in reply to: rmn
hi,
It looks this post was marked as solved by mistake?
anyway, the original description shows the Excel file cannot be found. Have you tried with absolute path to see if it works? e.g.
MultiValue.List("Material") = GoExcel.CellValues("C:\MWW Materials (Inventor).xlsx", "VP", "A2", "A600")
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
rmn
Member
rmn
Message 4 of 4 (168 Views)
01-15-2013 06:07 PM in reply to: xiaodong.liang
Yes, in this instance when using Vault and creating a template it is necessary to give an absolute path which I have done and solves the problem. The only additional requirement was to add this path as a library in the .ipj. Thanks for your response.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
