Inventor Customization
Active Contributor
OkieWolf
Message 1 of 29 (449 Views)
iLogic Variable Transfer
449 Views, 28 Replies
02-16-2011 12:39 PM
I have a rule which contains the Main and three Subs. I need to transfer variables between Subs. Normal VB doesn't seem to work. It doesn't error out. It just doesn't do it.
For example, I call a Sub from Main :
SwapPipe (oCompOcc, CurrentSize, NozzleSize)
The Sub beginning looks like :
Sub SwapPipe(compOcc as Inventor.ComponentOccurrence, CurrentSize As String, NozzleSize As String)
Then that Sub calls another Sub as:
InitialSize(compOcc, CurrentSize)
And that Sub beginning looks like:
Sub InitialSize(ScompOcc as Inventor.ComponentOccurrence, CurrentSize As String)
So, as an example, I would think that the variable CurrentSize would transfer between all these. But it isn't.
Any help is greatly appreciated.
Employee
Message 2 of 29 (423 Views)
Re: iLogic Variable Transfer
02-18-2011 06:58 AM in reply to: OkieWolf
That should work.  What version of Inventor are you using?
You can try adding the line:
Option Explicit On
and maybe
Option Strict On
to the top of your rule.  That might give you some compiler error messages about undeclared variables.
Mike Deck
Software Developer
DLS - Mechanical Design
Autodesk, Inc.
Active Contributor
OkieWolf
Message 3 of 29 (418 Views)
02-18-2011 08:02 AM in reply to: MjDeck
Inventor 2011 64bit.
OS = Windows 7.
I agree it should work but there are lots of things I've found in iLogic that you can do in Dot Net but not in iLogic.
But variable transfer is simple and I just can't understand why it won't do it.
Active Contributor
OkieWolf
Message 4 of 29 (417 Views)
02-18-2011 08:26 AM in reply to: OkieWolf
I added Option Explicit On, but didn't get anything useful returned.
Employee
Message 5 of 29 (409 Views)
02-18-2011 10:45 AM in reply to: OkieWolf
Can you post the complete rule?  That would help me to figure out what's going on.
Mike Deck
Software Developer
Autodesk, Inc.
Active Contributor
OkieWolf
Message 6 of 29 (407 Views)
02-18-2011 10:54 AM in reply to: MjDeck
I can but I think I may have found a way around it. I'm now trying to eliminate the subs, condense down the code, and just put it all in the main.
Active Contributor
OkieWolf
Message 7 of 29 (406 Views)
02-18-2011 10:57 AM in reply to: OkieWolf
I do have another question. Are you the one that wrote the external rule for the Content Center replacer for iLogic?
Employee
Message 8 of 29 (404 Views)
02-18-2011 11:07 AM in reply to: OkieWolf
Yes, I can take credit or blame for that code.
Mike Deck
Software Developer
Autodesk, Inc.
Active Contributor
OkieWolf
Message 9 of 29 (402 Views)
02-18-2011 11:12 AM in reply to: MjDeck
Ok, good. I'm using it in my current program.
Basically I have a 150# nozzle which consists of a 150# flange and a pipe. Both are Content Center parts. I can swap the flange out without issue but I'm having difficulty with the pipe. How do I put that in the replacer command so that Content Center knows to ONLY replace the size and leave the schedule and length alone?
Then, secondary to that, how do I  put that in the replacer command so that I can change any of those?
Active Contributor
OkieWolf
Message 10 of 29 (365 Views)
02-21-2011 07:08 AM in reply to: OkieWolf
Any news on this?
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
