Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic Sort Values
5 REPLIES 5
ddavis
4161 Views, 5 Replies
iLogic Sort Values
I have an iLogic rule that populates the fields shown below in our title block. The DIM. Values are strings set with H,W,L values. This works well, but I have an additional need to sort these values in ascending order, so the smallest value is first followed by the next largest and finally the largest value. (4.000x5.000x14.000). I haven't had much luck finding any information about how this can be done. I did however come across some code here that someone else was using for a similar feature.
Dim sizes As New List (Of Decimal)
sizes.Add(bH)
sizes.Add(bW)
sizes.Add(bL)
sizes.Sort()
D1 = sizes(1)
D2 = sizes(2)
D3 = sizes(3)
This is what I have been attempting, though it does not work. I get the following error "Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index". I'm not sure if my list type is correct (Decimal), but no matter what I choose it fails. The (bH,bW,bL) are the actual block dimensions pulled from the .ipt file. Once sorted I want the values of each position (1),(2),(3) to be assigned to (D1),(D2),(D3) so I can place them in my title block in the correct order.
I'm no expert with this and really appreciate any help anyone can provide. If there is a need to see the complete code and/or example files, please let me know.
Thank you,
Darek
5 REPLIES 5
Spidermeld
in reply to: ddavis
First time posting here.  I have been working on a similar rule.  Here's how I did the sort.
' Get overall Sizes
Dim x = Measure.ExtentsLength
Dim y = Measure.ExtentsWidth
Dim z = Measure.ExtentsHeight
' DEBUG - Displays sizes
'MessageBox.Show("Material Size = " & x & ", " & y & ", " & z, "Overall Sizes")
' Sorts sizes from lowest to highest
Dim Height = MinOfMany (x, y, z)
Dim Length = MaxOfMany (x, y, z)
Dim Width As Double
If (Height = x And Length = y) Or (Height = y And Length = x)Then
	Width = z
Else If (Height = x And Length = z) Or (Height = z And Length = x)Then
	Width = y
Else If (Height = y And Length = z) Or (Height = z And Length = y)Then
	Width = x
 Hope it helps
MegaJerk
in reply to: ddavis
To sort through things, you can use the below method to get a good understanding of how it works :
Dim ourArray As New ArrayList
Dim i As Integer
Dim Num1 As Double = 5.015
Dim Num2 As Double = 6.501
Dim Num3 As Double = 1.055
Dim Sum1 As Double
Dim Sum2 As Double
Dim Sum3 As Double
Dim holderList As String
ourArray.Add(Num1)
ourArray.Add(Num2)
ourArray.Add(Num3)
ourArray.Sort()
Sum1 = ourArray(0)
Sum2 = ourArray(1)
Sum3 = ourArray(2)
For i = 1 To ourArray.Count Step 1
''' This is cycling through each element of this array
''' and adding it to a String called 'holderList'.
''' This would be a great place to do something like
''' populating your fields, or assigning values
''' to your parameters.
holderList = holderList & CStr(ourArray(i-1)) & ", "
Next
MessageBox.Show("Array has been sorted down to: " & holderList,"")
MessageBox.Show("Our Sums equal : " & Sum1 & " - " & Sum2 & " - " & Sum3)
You can see where I show you both ways of getting values from this sort of approach. Because I'm almost sure that you will be working with a fixed array size, you can simply hardcode it as is shown using the Sum1 / Sum2 / Sum3 method, however, if you're ever looking to get values from a dynamic array, you can use that For / Next section to grab the value with each pass of the loop!
So really, if you're sure that you are using a fixed array amount that will never change (and assuming that your initial post contained the correct Parameter names), the following code will probably work best for you :
ourArray.Add(bH)
ourArray.Add(bW)
ourArray.Add(bL)
ourArray.Sort()
D1 = ourArray(0)
D2 = ourArray(1)
D3 = ourArray(2)
Remember that Arrays typically start at '0' where as the number that is returned when using the .Count method is the total of all elements inside of the Array. That's why D1 = ourArray(0)  instead of ourArray(1), and also why (if you were to use the example 1 code) -
MessageBox.Show(ourArray.Count)
Would return the value of 3
Further reading about ArrayLists can be found here :
I hope that this helps!
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
ddavis
in reply to: ddavis
Thank you both for the suggestions. I ended up using MegaJerks method as it was a few less lines of code.
Thanks again fellas, I really appreciate it.
Darek
Daan_M
in reply to: Spidermeld
wrong post...
Dim W As Double = 1
Dim H As Double = 2
Dim T As Double = 3
Dim firstplace = MinOfMany(W, H, T)
Dim lastplace = MaxOfMany(W, H, T)
Dim middleplace As Double
If 	firstplace <> W And lastplace<>  W Then
	middleplace = W
Else If firstplace  <>  H And lastplace <>  H Then
	middleplace = H
Else
	middleplace = T
MessageBox.Show(firstplace & middleplace & lastplace)
Daan_M
in reply to: ddavis
