I am trying to create a iLogic Rule that will measure the Length, Width and Thickness of a part and ut it into the custom fields we have. I am having a hard time rememebring how to get it to do it from the assembly level. I want to run this on the assembly and have it populate all the parts inside of it. The code below will do it for a part but what is it I add to get it to drill down into the assembly?
iProperties.Value("Custom", "THICKNESS")=Measure.ExtentsHeight
iProperties.Value("Custom", "WIDTH")=Measure.ExtentsWidth
iProperties.Value("Custom", "LENGTH")=Measure.ExtentsLength
Then I want ti to add this formyual to the Stock Number iProperty = <Length> X <Width> I can get it to add the values but I can not get it to add the formual to the stock number.
I have 10,000 things to do and I can not concentrate long enough to figure this one out. Any help would be apprciated!
I am trying to get it to drill down into the part and fill out this info...
Format:HTML Format
Version:1.0
StartHTML: 165
EndHTML: 4413
StartFragment: 314
EndFragment: 4381
StartSelection: 314
EndSelection: 314
compo=Component.InventorComponent("PartA:1")
Try
iProperties.Value(compo, "Custom", "THICKNESS")=compoMeasure.ExtentsHeight
iProperties.Value(compo, "Custom", "WIDTH")=compoMeasure.ExtentsWidth
iProperties.Value(compo, "Custom", "LENGTH")=compoMeasure.ExtentsLength
Catch
EndTry
Something like :
'Assuming that you have three custom Properties named "MegaThickness" , "MegaLength", and "MegaWidth" I believe this will do what you'd like ' 'Be sure to fill out the correct custom properties that you actually are using ;) iProperties.Value("PartA:1", "Custom", "MegaThickness") = Measure.ExtentsHeight iProperties.Value("PartA:1", "Custom", "MegaLength") = Round(Measure.ExtentsLength,2) iProperties.Value("PartA:1", "Custom", "MegaWidth") = Round(Measure.ExtentsWidth,2) iProperties.Value("PartA:1", "Project", "Stock Number") = _ iProperties.Value("PartA:1", "Custom", "MegaLength") & " X " & iProperties.Value("PartA:1", "Custom", "MegaWidth")
Does that help you?
Looks like what I want at the part leve... Will this drill down from an assembly or does it have to be ran from each part? I want to run it at the assembly level and let it fill these out...
MegaJerk it looks like you did somehting similar in this post... http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Run-ilogic-rule-in-each-part-from-the-...
If I add my Custom prop iLogic to this will this do what I am talking about you think?
Something like this?
Dim openDoc As Document openDoc = ThisDoc.Document Dim docFile As Document If openDoc.DocumentType = 12291 Then For Each docFile In openDoc.AllReferencedDocuments If docFile.DocumentType = 12290 Then Dim FNamePos As Long FNamePos = InStrRev(docFile.FullFileName, "\", -1) Dim docFName As String docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos) If iProperties.Value(docFName, "Custom", "THICKNESS")="" Then iProperties.Value(docFName, "Custom", "THICKNESS") = Measure.ExtentsHeight If iProperties.Value("Custom", "WIDTH")="" Then iProperties.Value("Custom", "WIDTH")= Measure.ExtentsWidth If iProperties.Value("Custom", "LENGTH")="" Then iProperties.Value("Custom", "LENGTH")= Measure.ExtentsLength End If End If Next Else MessageBox.Show("You must have a valid Assembly document open before using this code!", "File Type Mismatch!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation) End If
The code that I posted should be ran from the assembly, and works. Did you actually try using it? Is the problem now that you would like to update all of the parts (and in turn : iProperties) that are in the assembly ?
The code you last posted could work with some tweaking, but I don't believe that it will work in that current state.
I guess I will also have to tell it to create the custom prop if it does not exist...
Hi andrew.warren,
Here is some information on creating the custom prop if it does not exist:
http://inventortrenches.blogspot.com/2011/05/use-ilogic-to-add-and-use-custom.html
Also just a heads up, I took a couple of minutes to look at your overall goal, an noticed that Measure.ExtentsHeight runs on the top level assembly (and therefore gathers it's height) even when iterating through the assembly components via the For Each. Unfortunately I didn't find a solution, but will post back I think of something.
I hope this helps.
Curtis
'Define the open document Dim openDoc As Document openDoc = ThisDoc.Document Dim docFile As Document For Each docFile In openDoc.AllReferencedDocuments 'format file name Dim FNamePos As Long FNamePos = InStrRev(docFile.FullFileName, "\", -1) Dim docFName As String docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos) customPropertySet = docFile.PropertySets.Item _ ("Inventor User Defined Properties") 'check for custom iprops and add them if not found Try prop1 = customPropertySet.Item(“Thickness") prop2 = customPropertySet.Item(“Width") prop3 = customPropertySet.Item(“Length") Catch ' assume error means not found customPropertySet.Add("", “Thickness") customPropertySet.Add("", “Width") customPropertySet.Add("", “Length") End Try 'get value from model prop1.value = Measure.ExtentsHeight prop2.value = Measure.ExtentsWidth prop3.value = Measure.ExtentsLength Next
Yes that is what I want ti to to do, measure each part and return the part info into custom iprops as you created them. Dang, I did not want ti grabbing the assembly...
Ok between this, the three installs and the Subscription / additional seat order I am trying to place I have really screwed something up...
If I can not get it to work in the assembly I am fine with going into each part and running it. I want ti to create the custom props if they do not exist then get the Length Width and Thickness. Just as you had in the Assembly but I want ti to run in the part now. I tried to modify the code but ti was like trying to untangle Christmas tree lights blindfolded with all the people coming and going from my desk.
I am not even sure why we/they use the Custom but this is my third week here...
Any help is greatly apprciated!
Does this look correct?
I think I got it...
'check for custom iprops and add them if not found Dim propertyName1 As String = "Length" Dim propertyName2 As String = "Width" Dim propertyName3 As String = "Thickness" customPropertySet = ThisDoc.Document.PropertySets.Item _ ("Inventor User Defined Properties") Try prop = customPropertySet.Item(propertyName1) prop = customPropertySet.Item(propertyName2) prop = customPropertySet.Item(propertyName3) Catch ' Assume error means not found customPropertySet.Add("", propertyName1) customPropertySet.Add("", propertyName2) customPropertySet.Add("", propertyName3) End Try 'output the custom iproperties and update the file RuleParametersOutput() InventorVb.DocumentUpdate() iProperties.Value("Custom", "Length") = Measure.ExtentsLength iProperties.Value("Custom", "Width") = Measure.ExtentsWidth iProperties.Value("Custom", "Thickness") = Measure.ExtentsHeight 'update file iLogicVb.UpdateWhenDone = True
Hi andrew.warren,
What you have works, but I noticed an issue that might trip you up.
If the iprops are checked and added as a group, it could cause an error if one of them exists but the others don't. So here's a version that checks/adds them one at a time. I've also added the measure extents to the check/add step, so that it just fills in the value as it the iProperty is checked/created.
I hope this helps.
Curtis
docFile = ThisDoc.Document
'check for custom iprop and add if not found
Try
customPropertySet.Item(“Thickness").Value = Measure.ExtentsHeight
Catch
' assume error means not found and add
customPropertySet.Add(Measure.ExtentsHeight, “Thickness")
End Try
Try
customPropertySet.Item(“Width").Value = Measure.ExtentsWidth
Catch
customPropertySet.Add(Measure.ExtentsWidth, “Width")
End Try
Try
customPropertySet.Item(“Length").Value = Measure.ExtentsLength
Catch
customPropertySet.Add(Measure.ExtentsLength, “Length")
End Try
I'm going to add this just in case someone might find it helpful, or in case this can be used to find a solution to getting the size for each component in the assembly. This rule does pretty much the same thing the other does, but as written it writes the extents info all to one custom iProperty named Size (example: Size: 0.3 in. x 0.3 in. x 0.3 in.) It also formats the length of the size string. (example: 0.25 becomes 0.3 in. )
I hope this helps.
Curtis
'check for custom iprops and add them if not found Dim propertyName1 As String = "Size" customPropertySet = ThisDoc.Document.PropertySets.Item _ ("Inventor User Defined Properties") Try prop = customPropertySet.Item(propertyName1) Catch ' Assume error means not found customPropertySet.Add("", propertyName1) End Try ' Get the active document. This assumes it is a part document. Dim oPartDoc As PartDocument oPartDoc = ThisApplication.ActiveDocument Dim oBox As Box oBox = oPartDoc.ComponentDefinition.SurfaceBodies.Item(1).RangeBox 'set IncludeLeadingDigit option 'optional 'use TriState.True to return a number such as 0.123 'use TriState.False to return a number such as .123 'use TriState.UseDefault to use the computer's regional settings LeadZero = TriState.True 'set NumDigitsAfterDecimal option 'optional DecNum = 1 'set UseParensForNegativeNumbers 'optional 'use TriState.True to return a negative number as: (49.123) 'use TriState.False to return a negative number as: -49.123 'use TriState.UseDefault to use the computer's regional settings NegFormat = TriState.False 'set GroupDigits to include group delimiter specified (as specified in the locale settings) 'optional 'use TriState.True to return a number as: 1,234 (where comma is the locale setting) 'use TriState.True to return a number as: 1234 'use TriState.UseDefault to use the computer's regional settings GroupDigits = TriState.False Length1 = (oBox.MaxPoint.X - oBox.MinPoint.X) * 0.394 '& " in." Width1 =(oBox.MaxPoint.Y - oBox.MinPoint.Y) * 0.394 '& " in." Thickness1 = (oBox.MaxPoint.Z - oBox.MinPoint.Z) * 0.394 '& " in." Length = FormatNumber(Width1, DecNum, LeadZero, NegFormat, GroupDigits) Width = FormatNumber(Length1, DecNum, LeadZero, NegFormat, GroupDigits) Thickness = FormatNumber(Thickness1, DecNum, LeadZero, NegFormat, GroupDigits) 'MessageBox.Show("Extents = " & Thickness & " in. x " & Length & " in. x " & Width & " in. " , "Title") iProperties.Value("Custom", "Size") = Thickness & " in. x " & Length & " in. x " & Width & " in. "
This is really what we wanted but we want the longest dim in x,y or z to be length, then the next longest plane to be width and then the longest int the last plane to be thickness. Any ideas their?
I guess I could just return these results to a list then say the longest = L next longest = width and shortest = thick?
Would Opening each part and setting it to the current Active part not allow you to take the appropriate measurements?
You could open the part, do what you wish, then update, save, and close each part as it iterates through them.
Example:
docName = ThisDoc.Path & "\" & "Part Name" & ".ipt"
doc = ThisApplication.Documents.Opne(docName, True) < True sets the part to be the current active document
doc.Update()
/////////////////// Do what you'd like /////////////
doc.Save()
doc.Close()
So far Murphy is kicking my butt again, between licensing, Meetings with IT about Licensing and etc, I have not gotten this done...
Here is what I have so far...
I can create the parameters in the parts but I have not gotten the iLogic to drill down from the assembly level. I also need to return those values to a list then sort them by size so the Length = Longest measured Bounding box plane, Width = the next and then Thickness = the shortest measured plane.
I am having a ahrd time getting all three of these to work in the same code? Any ideas?
I have implemented this rule but i'm stumbling upon an exception of use for this rule.
Suppose you have created your part with the use of "Make Components", nothing wrong with that but, ... (And this is where i have found the "exception", if your part is not designed perpendicular to at least 2 of the axis X,Y or Z, you get wrong results.
An example:
Suppose picture below (you'll get the idea instantaneously 😉 )
Now according to common sense my bounding box should be 10 x 50 x Height, but when i apply the rule to this part, my bounding box becomes :
Any ideas on how to overcome this?
Change UCS on demand of the Bounding Box?
