Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic Forms Picture Folder?
5 REPLIES 5
meck
3272 Views, 5 Replies
What is it for and how do I use it?
Will it allow me to switch between different pictures for display on my iLogic form?
If so? How do I set which picture to display?
Where can I get more in depth help on this stuff?????
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
5 REPLIES 5
MjDeck
in reply to: meck
When you drag in a Picture Fodler object, it contains two Picture objects.  You can add more.
- Click on each Picture object, click on the Image property and browse to a bitmap file.
- Change the Label (name) of each Picture object to something meaningful.
- Create a Text parameter (named PictureName or something similar) in your part or assembly.  Make it a multi-value parameter.  Set the possible values to be the same as the labels (names) of the Picture objects that you have just named.
- Add another Picture object to your form.  Add it outside of the Picture folder.  This will be a visible object, shown on the form.
- Click on the Picture Parameter Name property of that new Picture object.  Set it to the name of your Text parameter (PictureName in this example).
 Then you can use a rule to drive the value of the PictureName parameter.  This will change the image in the form.
Mike Deck
Software Developer
Autodesk, Inc.
meck
in reply to: MjDeck
Thanks Mike!
Mike Eck
Using Inventor 2018
in reply to: meck
in reply to: MjDeck
Hi all,
 I have a similar problem to this. Can I switch between the images by selecting difrent tabs in my form ? I want to update the image by the selected tab. capture.png
I have tried "if" or "select case" and neither one worked. as I am saying Stair_Properties = True it only makes the tab active. It doesnt indicate if it is selected, here is the code :
If Stair_Properties = True Then
Image = "Image 01"
If Railing_Properties = True Then
Image = "Image 02"
If Riser_Properties = True Then
Image = "Image 03"
'Select Case Image
'Case Stair_Properties
'Image = "Image 01"
'Case Railing_Properties
'Image = "Image 02"
'Case Riser_Properties
'Image = "Image 03"
'End Select
Any help would be great...
meck
There are no events to trigger the switch of a picture by clicking on a tab. What I would do is place a picture on each tab with what I way to convey.
Mike Eck
Using Inventor 2018
