Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic Coding to Disable Event Triggers
1 REPLY 1
1506 Views, 1 Reply
Hi Everyone,
I have a question. I am setting up template .ipts and .idw for my company, and i run Adept to save and store my files. Now i have a code to automatically make a .idw after i save an .ipt. but then after every save (adept saves the .ipt alot of times) it will ask to make a drawing for the .ipt. well i was wondering if there is a code to put in a rule to disable the event triggers, and place that rule on the trigger after close document. so that the next time i open the document no event triggers will work.
1 REPLY 1
Vladimir.Ananyev
You may suppress / unsuppress any iLogic rule. Here is a sample:
Dim MyRuleName As String = "MagicRule"
Dim auto As IiLogicAutomation = iLogicVb.Automation
Dim oDoc as Inventor.Document = ThisDoc.Document
Dim rule As iLogicRule = auto.GetRule( oDoc, MyRuleName)
'this line suppresses my rule
rule.IsActive = False
Suppressed rule cannot be invoked by events.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
