Hi all!
I'm using ilogic rules to customize an assembly generated by content center of frame generator. I would like replace the parts on my assembly when I change an assembly parameter multivalue.
Is possible??
Thanks!
I am also looking for the same option...
I am doing standardization of frames. I need one frame assembly in common for all needs.
Looking for ilogic option to change the frame size.
Request you to kindly help
Carthik Babu
Babcock Borsig Softtech Private Ltd
Dear Sir,
Request you to provide what command i have to use in ilogic.
If i have to make it only by VB Plugin. Kindly ping me the VB codes for the same. I am in the process of learning VB coding to make Inventor Plugin. Request you to kindly help me regarding the same
Carthik
