Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic 3rd Party object visibility in Drawing environment
1 REPLY 1
733 Views, 1 Reply
Greetings to all .
Hope you can help me. I have a file with idw extension, on a sheet which show an embedded spreadsheet with relevant information about the product specification. It happens that the same product can make you different specifications (for now only two ) which led me to have two files with the only difference being the aforementioned spreadsheet. With the help of iLogic, I want this to change , creating a multivalued parameter with iLogic code That change the information displayed on the spec sheet . So, I thought the following ideas:
1) Create two embedded spreadsheet ( or how many you need ) and remove all visibility except for the concerned.
2) Create a single spreadsheet with all possible specifications and the drawing sheet showing me only for the current parameter a specific range.
3) Create the table and its variants completely with iLogic code .
Although they are good ideas, and all I would be useful, I just have a little problem ... so far I as I refer to a 3rd Party object in the environment iLogic , so I would appreciate a lot if I give advice and share with me your experience , because it seems very useful and I think it's strange that no one asked this before.
1 REPLY 1
adam.nagy
One issue that might influence your decision is that it seems that programmatically you can only control the visibility of the 3rd party object for the sheet where it was originally inserted. Through the UI you can make the same object visibile in multiple sheets, but then cannot control it through the API.
So if you are working with multiple sheets it might be better to go with a custom table that you fill with data yourself.
You can store data in Attributes as well inside a document, so xls might not be necessary here.
There are blog posts about the 3 main ways you can store custom data in documents:
http://adndevblog.typepad.com/manufacturing/2013/03/save-extra-data-in-inventor-file-1.html
http://adndevblog.typepad.com/manufacturing/2013/03/save-extra-data-in-inventor-file-2.html
http://adndevblog.typepad.com/manufacturing/2013/03/save-extra-data-in-inventor-file-3.html
Cheers,
Adam Nagy
Autodesk Platform Services
