Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
how to open custom properties window using vba
6 REPLIES 6
akosi
737 Views, 6 Replies
6 REPLIES 6
Gruff
in reply to: akosi
I do not think there is an API to open the properties window.
However you can create your own dialog and populate it using API properties functions.
Basically create your own properties window.
akosi
in reply to: Gruff
good idea...thanks!!Smiley Happy
ekinsb
in reply to: akosi
It is possible to execute the iProperties command from the API.  The following VBA code will do it.  However, it's not possible to set it to the Custom tab once the dialog is displayed.
Public Sub StartiPropertiesCommand()
    Dim controlDefs As ControlDefinitions
    Set controlDefs = ThisApplication.CommandManager.ControlDefinitions
    Select Case ThisApplication.ActiveDocument.DocumentType
        Case kAssemblyDocumentObject
            controlDefs.Item("AssemblyiPropertiesCmd").Execute
        Case kPartDocumentObject
            controlDefs.Item("PartiPropertiesCmd").Execute
        Case kDrawingDocumentObject
            controlDefs.Item("DrawingiPropertiesCmd").Execute
        Case kPresentationDocumentObject
            controlDefs.Item("PresentationiPropertiesCmd").Execute
    End Select
End Sub
To learn more about directly running Inventor commands see:
http://modthemachine.typepad.com/my_weblog/2009/03/running-commands-using-the-api.html
Brian Ekins
Mod the Machine blog
akosi
in reply to: ekinsb
this is great ekinsb!!!!Smiley LOL
can i choose the particular tab show? like for example : the custom tab...is it possible?
ekinsb
in reply to: akosi
This just executes the command, the same as if you run the command in the UI.  It's not possible to set the tab through the API.  It might be possible using the Windows API, but that wouldn't be simple.
Brian Ekins
akosi
in reply to: ekinsb
thanks a lot anyway.....
this is still a big help   Smiley LOL
