Inventor Customization
Active Contributor
shirazbj
Message 1 of 7 (337 Views)
Accepted Solution
how to know if a view is baseview with vb.net?
337 Views, 6 Replies
02-05-2013 03:01 AM
While loop through all Views in a sheet, I can use oView.ScaleFromBase to know if the scale of the view is changed from Base-View. Like this:
  For Each oView In oViews
                If oView.ScaleFromBase = False Then
'This view's scale is different from that of the Base-View
 But I can't tell in this way if it is a Base-View or views with different view scale.
There is a oView.ViewType,  I tried this
Dim mytype As String
mytype = oView.ViewType
for Base-View, mytype=10501
for other-view with different scale, mytype=10504
Is there other property I could use? Can't work out how to get the View Type Name.
Thanks for help.
Peter
ADN Support Specialist
Vladimir.Ananyev
Message 2 of 7 (332 Views)
Re: how to know if a view is baseview with vb.net?
02-05-2013 07:00 AM in reply to: shirazbj
You may check oView.ParentView property.
For base view it returns Nothing.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Active Contributor
shirazbj
Message 3 of 7 (320 Views)
02-05-2013 04:47 PM in reply to: Vladimir.Ananyev
Hi Vladimir,
I tried this, but both baseview and view whose scale if different from baseview return a Nothing.
Peter
            Dim myView As DrawingView
                    myView = oView.ParentView
                    If myView Is Nothing Then
                        MsgBox("nothing")
                    Else
                        MsgBox("something")
                    end if
                 end if
             next
Employee
yuhanzhang
Message 4 of 7 (311 Views)
02-06-2013 01:48 AM in reply to: shirazbj
Can you attach the data that you see the problem? Or double check the drawing view which has different scale from its parent view does have a parent view or not?
Rocky Zhang
Inventor API
Manufacturing Solutions
Autodesk, Inc.
Active Contributor
Robert..F
Message 5 of 7 (301 Views)
02-07-2013 07:13 AM in reply to: shirazbj
You can check this way:
For each oView in oViews
     If oView.ViewType = Inventor.DrawingViewTypeEnum.kStandardDrawingViewType Then
          Debug.Print("This is a base view")
     Else
          Debug.Print("This is not a base view")
Next
 Or you can check the oView.Aligned property but this will also return false if the alignment has been broken from the base view.
Active Contributor
shirazbj
Message 6 of 7 (287 Views)
02-08-2013 03:44 PM in reply to: yuhanzhang
Hi Rocky,
I just made a cube and generated a base view, a top view,a right view and an iso view. Then I change the view scale of the iso view.
Then I want the code to tell me which one's scale is changed and it is not a base view.
Peter
Active Contributor
shirazbj
Message 7 of 7 (285 Views)
02-08-2013 03:45 PM in reply to: Robert..F
Hi Robert,
It's works for me. thank you very much.
Peter
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
