Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
how to delete value in iproperties using vba
3 REPLIES 3
akosi
995 Views, 3 Replies
while in assembly, i would like to select a subpart and be able to clear or delete the value of ex description without opening the part file.
i can delete properties in custom prop but i cant do it in description.
ive use design tracking properties but to no avail..Smiley Sad
3 REPLIES 3
ekinsb
in reply to: akosi
It sounds like you've already got the code that gets the document containing the iProperties.  The function below will clear the description property, given a document.
Public Sub ClearDescription(Doc As Inventor.Document)
    Dim propSet As PropertySet
    Set propSet = Doc.PropertySets.Item("Design Tracking Properties")
    Dim descProp As Property
    Set descProp = propSet.Item("Description")
    descProp.value = ""
End Sub
Brian Ekins
Inventor and Fusion 360 API Expert
Mod the Machine blog
ADNpati
in reply to: akosi
Sub ClearDescription()
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
oAsmDoc.PropertySets.item(3).item(14).Value = ""
End Sub
 You can see the full details of part or sembly in watch window using VBA.
Mechanical Engineer
Inventor Applications Engineer
If my solution seems to remedy your problem, please press the Accept Solution button, Some KUDOS -
akosi
in reply to: ekinsb
>>>>>>>>>>ekinsb & adnpati
thanks for answering...really appreciate it..
i didnt try the  descProp.value = ""
i keep doing the delete value like im doing in custom prop...
anyway..thanks a lot guys
