Usually I use the TextBoxes. But its text would not change.
How to use vb.net to add a prompted text into the definition of a sketched symbol?
Peter
Hi Peter,
There is a sample that does that from the Help Files, see SketchedSymbolDefinition Interface:
Public Sub CreateSketchedSymbolDefinition() ' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument Set oDrawDoc = ThisApplication.ActiveDocument ' Create the new sketched symbol definition. Dim oSketchedSymbolDef As SketchedSymbolDefinition Set oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Add("Circular Callout") ' Open the sketched symbol definition's sketch for edit. This is done by calling the Edit ' method of the SketchedSymbolDefinition to obtain a DrawingSketch. This actually creates ' a copy of the sketched symbol definition's and opens it for edit. Dim oSketch As DrawingSketch Call oSketchedSymbolDef.Edit(oSketch) Dim oTG As TransientGeometry Set oTG = ThisApplication.TransientGeometry ' Use the functionality of the sketch to add sketched symbol graphics. Dim oSketchLine As SketchLine Set oSketchLine = oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(0, 0), oTG.CreatePoint2d(20, 0)) Dim oSketchCircle As SketchCircle Set oSketchCircle = oSketch.SketchCircles.AddByCenterRadius(oTG.CreatePoint2d(22, 0), 2) Call oSketch.GeometricConstraints.AddCoincident(oSketchLine.EndSketchPoint, oSketchCircle) ' Make the starting point of the sketch line the insertion point oSketchLine.StartSketchPoint.InsertionPoint = True ' Add a prompted text field at the center of the sketch circle. Dim sText As String sText = "<Prompt>Enter text 1</Prompt>" Dim oTextBox As TextBox Set oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(22, 0), sText) oTextBox.VerticalJustification = kAlignTextMiddle oTextBox.HorizontalJustification = kAlignTextCenter Call oSketchedSymbolDef.ExitEdit(True) End Sub Public Sub InsertSketchedSymbolOnSheet() ' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument Set oDrawDoc = ThisApplication.ActiveDocument ' Obtain a reference to the desired sketched symbol definition. Dim oSketchedSymbolDef As SketchedSymbolDefinition Set oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Item("Circular Callout") Dim oSheet As Sheet Set oSheet = oDrawDoc.ActiveSheet ' This sketched symbol definition contains one prompted string input. An array ' must be input that contains the strings for the prompted strings. Dim sPromptStrings(0) As String sPromptStrings(0) = "A" Dim oTG As TransientGeometry Set oTG = ThisApplication.TransientGeometry ' Add an instance of the sketched symbol definition to the sheet. ' Rotate the instance by 45 degrees and scale by .75 when adding. ' The symbol will be inserted at (0,0) on the sheet. Since the ' start point of the line was marked as the insertion point, the ' start point should end up at (0,0). Dim oSketchedSymbol As SketchedSymbol Set oSketchedSymbol = oSheet.SketchedSymbols.Add(oSketchedSymbolDef, oTG.CreatePoint2d(0, 0), (3.14159 / 4), 0.75, sPromptStrings) End Sub
Philippe.
