Trying to export a PDF with PDF translator. Using sample "Save as PDF Translator Sample API Sample" from programers help, I created an addin but...
Getting error "Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))" on "ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")".
I created an addin starting with
Imports Inventor Imports System.Runtime.InteropServices Namespace IvPublish <ProgIdAttribute("IvPublish.StandardAddInServer"), _ GuidAttribute("5404f6be-46bb-4bf2-b1b4-7a5e70b69e8f")> _ Public Class StandardAddInServer Implements Inventor.ApplicationAddInServer ' Inventor application object. Public Property ThisApplication As Inventor.Application
and activate starts with
Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate ' Initialize AddIn members. ThisApplication = addInSiteObject.Application
and command triggered with a button starts with
Private Sub _ExportPdfAllButton_OnExecute(Context As NameValueMap) Handles _ExportPdfAllButton.OnExecute Dim PDFAddIn As TranslatorAddIn PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
And that is where it fails... getting PDFAddin. Tried on two systems with same result...
Inventor 2014, Visual Studios 2012
Stan
Solved by sellis. Go to Solution.
Should also note that this works fine...
Dim oSTEPTranslator As TranslatorAddIn
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
