copy part *.ipt to clipboard
5 REPLIES 5
707 Views, 5 Replies
Is there any code similar to one below that copys part.ipt to the clipboard?
Imports System.Windows.Forms
Sub Main
   Clipboard.SetText(Description)
End Sub
 Any help is appreciated.
5 REPLIES 5
ekinsb
Can you please be a more specific about what you need and what you're trying to do.  I'm unclear if you want it to be the equivalent of selecting a .ipt file in Windows Explorer and doing ctrl-C or selecting the top node in the browser and doing ctrl-C or even something else.  The results in the two cases I mentioned, as far as what goes on the clipboard, are completely different.
Brian Ekins
Mod the Machine blog
in reply to: ekinsb
Brian,
I`m trying to find a code equivalent to selecting an ipt part In inventor in the assembly view tree and doing CTRL+C.
Thank you,
ekinsb
There isn't direct exposure of the Copy and Paste functionality on the ComponentOccurrence object, which is the API object that represents each of the nodes in the assembly tree (parts and subassemblies).  However, it is possible to directly call Inventor commands.  The code below illustrates this.
Public Sub CopyPaste()
    Dim asmDoc As AssemblyDocument
    Set asmDoc = ThisApplication.ActiveDocument
    Dim occ As ComponentOccurrence
    Set occ = asmDoc.ComponentDefinition.Occurrences.ItemByName("L:1")
    ' Get references to the copy and paste commands.
    Dim controlDefs As ControlDefinitions
    Set controlDefs = ThisApplication.CommandManager.ControlDefinitions
    Dim copyCommand As ControlDefinition
    Set copyCommand = controlDefs.Item("AppCopyCmd")
    Dim pasteCommand As ControlDefinition
    Set pasteCommand = controlDefs.Item("AppPasteCmd")
    ' Select the occurrence.
    asmDoc.SelectSet.Clear
    Call asmDoc.SelectSet.Select(occ)
    ' Execute the copy command.
    copyCommand.Execute
    ' Execute the paste command.
    pasteCommand.Execute
End Sub
Brian Ekins
in reply to: ekinsb
Great! it works! I would never come up with something similar myself!
Thanks!
DeerSpotter
in reply to: ekinsb
this doesnt work anymore, could you please fix?
Image and video hosting by TinyPic
See My LinkedIn Profile
