I have a part where I have placed a text on a sketch.
I control this text with two rules.
One rule, PaneelNummer, to give the number and a rule, PlaatsPaneelNummer, is to place the number in the part.
The numbers are written to the iproperties and BOM.
If I now place the part into an assy I would like to control rules in the assy.
The rule PaneelNummer works but when I want to place the text I get a message that the sketch which the text is placed in the part can not be found.
May that mean that I have to place sketch with the text in the assy or can I somehow link the sketch into the assy?
Solved by jostroopers. Go to Solution.
Instead of using the vb rule i linked a text parameter to the text.
That parameter i link in the assy to the iproperties.
The iproperties in the assy are controlled by a rule.
It's easyer this way and i don't have to use the vb code.
