hi
i need some help in opening a specific folder and user can select the file using vba.
i need to include it in the rest of my macro.
please help
Hi akosi,
Here is an example:
Public Sub TestFileDialog() ' Create a new FileDialog object. Dim oFileDlg As FileDialog Call ThisApplication.CreateFileDialog(oFileDlg) ' Define the filter to select part and assembly files or any file. oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*" ' Define the part and assembly files filter to be the default filter. oFileDlg.FilterIndex = 1 ' Set the title for the dialog. oFileDlg.DialogTitle = "Open File Test" ' Set the initial directory that will be displayed in the dialog. oFileDlg.InitialDirectory = "C:\Temp" ' Set the flag so an error will be raised if the user clicks the Cancel button. oFileDlg.CancelError = True ' Show the open dialog. The same procedure is also used for the Save dialog. ' The commented code can be used for the Save dialog. On Error Resume Next oFileDlg.ShowOpen ' oFileDlg.ShowSave ' If an error was raised, the user clicked cancel, otherwise display the filename. If Err Then MsgBox "User cancelled out of dialog" ElseIf oFileDlg.FileName "" Then MsgBox "File " & oFileDlg.FileName & " was selected." End If End Sub
This example came from here:
I hope this helps.
Curtis
this code doesnt work for me...
it doesnt point to whatever i put as the initial directory.
help help help!!!
