is it possible to change browser folder icon?
I'm not sure I understand the question. The folder icon of what and where exactly?
I think it would be useful to provide an image of what the current situation is vs. what you'd like to get.
Cheers,
Please find attached, The browser folder inside assembly document, To replace the standard icon with a custom icon
Changing the icon of a native browser node is similar to setting the icon of your own panel's client node, but you work with NativeBrowserNodeDefinition and set the OverrideIcon property instead.
Sub ChangeIcon() Dim bps As BrowserPanes Set bps = ThisApplication.ActiveDocument.BrowserPanes ' e.g. if you want to change the root node's icon ' in the assembly "Model" panel Dim bp As BrowserPane Set bp = bps("AmBrowserArrangement") Dim bmp As IPictureDisp Set bmp = LoadPicture("C:\Bitmap1.bmp") Dim cnr As ClientNodeResource ' Only Bitmaps are supported by the Add method
' and it should be 16x16 Set cnr = bps.ClientNodeResources.Add( _ "MyResource", 2, bmp) Dim nbnd As NativeBrowserNodeDefinition Set nbnd = bp.TopNode.BrowserNodeDefinition nbnd.OverrideIcon = cnr End Sub
I hope this helps.
Cheers,
Gives Add Method Error. See Attachment
I believe this code is unlikely to succeed on 64-bit because VBA is running out of process. You would need either to use 32-bit VBA or try the same from a VB.Net/C# add-in. The way to load resources if different however in .Net.
You can refer to the following articles:
http://adndevblog.typepad.com/manufacturing/2012/08/change-the-browser-node-icon.html
Philippe.
Attached is an iLogic rule that will work for an assembly or part document.
