Inventor Customization
Valued Mentor
jcneal
Message 1 of 7 (640 Views)
Accepted Solution
add sketch on part's face by vba
640 Views, 6 Replies
10-22-2012 01:32 PM
hi,
I can add sketch on a part's workplane (xy, xz, yz) by using sketchs.add.
is there anyway i can select a face of part and create a new sketch?
thanks for any tips.
Autodesk Inventor Professional 2014
Autodesk Product Design Suite Standard 2013
Microsoft Office 2007 & 2013
Windows 7 64bit
Synergis Adept 2013
Visual Studio Express 2010
*Expert Elite*
jdkriek
Message 2 of 7 (629 Views)
Re: add sketch on part's face by vba
10-23-2012 09:07 AM in reply to: jcneal
Here's one method I use on Extruded parts, but hopefully you can gleem enough from it.
Sub Sketch2Face2()
'J.Kriek 2012
    Dim oApp As Application
    Set oApp = ThisApplication
    Dim oPart As PartDocument
    Set oPart = oApp.ActiveDocument
    Dim oCompDef As ComponentDefinition
    Set oCompDef = oPart.ComponentDefinition
    Dim oExtrude As ExtrudeFeatures
    Set oExtrude = oCompDef.Features.ExtrudeFeatures
    Dim oFaces As Faces
    'This can be changed to .SideFaces, .EndFaces, or .StartFaces
    'But .Faces will let you choose between all faces
    Set oFaces = oExtrude.Item(1).Faces
    Dim oSketch As PlanarSketch
    'Put a sketch on the first face (1) - change to suit
    Set oSketch = oCompDef.Sketches.Add(oFaces(1), True)
End Sub
Jonathan D. Kriek
Autodesk Inventor Certified Expert
Microsoft Certified Application Developer
_____________________________________________________
Did I help you? Please choose Accept as Solution or Kudos below
Valued Mentor
jcneal
Message 3 of 7 (613 Views)
10-24-2012 09:41 AM in reply to: jdkriek
thanks a lot.
I modified your code to fit my need. It works fine.
I don't understand how you get .sidefaces, endfaces to work. I have to test few times to get face right. in thise case is oFace(4)
Is there any way I always get top face of a face feature in sheet metal part?
Windows 7 64bit
Synergis Adept 2013
*Expert Elite*
jdkriek
Message 4 of 7 (575 Views)
10-25-2012 06:35 AM in reply to: jcneal
SideFaces, EndFaces, ect is only available for extruded features. When dealing with sheetmetal faces features you can only choose the item number. And yes unfortunately it's a guessing game as to which number that is depending on how the face was created.
However, I did have a crazy idea...
You can obtain the .BaseFace from the flat pattern and since it's a face feature it's going to be the top face. It will create the sketch in the folded. This worked for me, but try it out.
Sub Sketch2FlatFace()
'J.Kriek 2012
    Dim oSheetMetalComp As SheetMetalComponentDefinition
    Set oSheetMetalComp = oPart.ComponentDefinition
    'Make sure there is a flat pattern
    If oSheetMetalComp.HasFlatPattern = False Then
        'Create flat pattern
        Call oSheetMetalComp.Unfold
        'Switch back to Folded
        Set oDef = oApp.CommandManager.ControlDefinitions.Item("PartSwitchRepresentationCmd")
        Call oDef.Execute
    Dim oFlatpattern As FlatPattern
    Set oFlatpattern = oSheetMetalComp.FlatPattern
    'Edit the flat pattern
    Call oFlatpattern.Edit
    'Grab the BaseFace (Top) - can also be .BottomFace
    Dim oFace As Face
    Set oFace = oFlatpattern.BaseFace
    'Exit the flat pattern
    Call oFlatpattern.ExitEdit
    'Sketch on Top Face
    Set oSketch = oSheetMetalComp.Sketches.Add(oFace, True)
    'Remove the flat pattern - optional
    'Call oFlatpattern.Delete
End Sub
Jonathan D. Kriek
Valued Mentor
jcneal
Message 5 of 7 (570 Views)
10-25-2012 08:51 AM in reply to: jdkriek
well, mine is front face. so the sketch goes to my flange side whick is top face.
I did face feature on x-y plane.
thanks a lot. I learn something from it.
Windows 7 64bit
Synergis Adept 2013
akosi
Message 6 of 7 (310 Views)
09-10-2013 10:20 AM in reply to: jdkriek
how to execute the 2d sketch command in vba?
akosi
Message 7 of 7 (303 Views)
09-10-2013 11:06 AM in reply to: jcneal
i want to select a face from a derived solid and project geometry to get a sketch.
can anybody help me with this?
thanks:smileyhappy:
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
