Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
X is not valid?
10 REPLIES 10
Message 1 of 11
jletcher
532 Views, 10 Replies
X is not valid?
Hard to explain this but I wil do my best.
 Making a part that will have the size as an option to pick. Issue is Ilogic does not like it.
 I have a list that has sizes like:
3" X 2"
4" X 2"
4" X 4"
But when I put in the code
If Plate_Size = "3" X 2"" Then
	Parameter("Dim_X") = 3
	Parameter("Dim_Y") = 2
	Parameter("Foot_Code") = "A"
ElseIf Plate_Size = "4" X 2"" Then
	Parameter("Dim_X") = 4
	Parameter("Foot_Code") = "B"
 it gives me an error
Error on Line 4 : End of statement expected.
and highlight the If Plate_Size ="3" X 2"".
I know it has to do with the X but I an't remember what to do having brain fart.
 Can someone refresh me.....
10 REPLIES 10
Message 2 of 11
GavoGarmo
in reply to: jletcher
I think the " marks are messing you up. iLogic will see the string as divided because the " will be seen as the start and end of a string.
Message 3 of 11
jletcher
in reply to: GavoGarmo
Yes you are correct. Is there a way to keep them? I know it has to do with a double something if I remember correctly..
Message 4 of 11
GavoGarmo
My only solution is to go metric! lol... Sorry 🙂
Message 5 of 11
GavoGarmo
I can see a workaround where you'd make addition parameters that have the value 3" x 2" and then write the code to say if PlateSize = NewParameter then ect.... It's a fudge but it should work and keep you moving forward.
Message 6 of 11
jletcher
Metric lol that would flip these rednecks out they don't even know what a weld symbol is LOL.
 Yeah i was thinking the same thing about the new parameter I guess I will just take them out for now..
Message 7 of 11
thomaskennedy
You should be able to put an 'extra' quotation mark in the string like this :
If Plate_Size = "3"" X 2""" Then
ElseIf Plate_Size = "4"" X 2""" Then
(The extra quotation mark will be ignored when the rule is compiled and run)
Cheers,
Tom
Message 8 of 11
jdkriek
Or you can use Chr(34) - less confusing programmatically IMO
If Plate_Size = "3" & Chr(34) & " X 2" & Chr(34) Then
ElseIf Plate_Size = "4" & Chr(34) & " X 2" & Chr(34) Then
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 9 of 11
jletcher
in reply to: thomaskennedy
Thanks that worked.. I thoght I tried that but I gues I did not..
Message 10 of 11
jletcher
in reply to: jdkriek
Thanks jdkriek your solution will work too...
Message 11 of 11
jdkriek
Quite welcome! 😉
Jonathan D. Kriek
