I'm trying to create an iLogic rule that will print a text string to a cell or coloum of a parts list in inventor.
My code so far...
Sub Main()
On Error Resume Next
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oPartsList1 As PartsList
oPartsList1 = oDrawDoc.ActiveSheet.PartsLists.Item(1)
oPartsList1.Sort("ITEM")
Dim DWGNUM As String = iProperties.Value("custom", "DWG Number")
SheetNumber = Mid(ThisDoc.Document.ActiveSheet.Name, InStr(1, ThisDoc.Document.ActiveSheet.Name, ":") + 1)
Dim j As String = 1
MessageBox.Show(DWGNUM+"-"+SheetNumber+"-"+j, "DXF Number")
End Sub
I want to print what is in the MessageBox into a cell in the parts list, and i am stumped.
The cell i am trying to print to is a custom property in the Parts List.
Any help is greatly appreciated!
Solved by TomTom111. Go to Solution.
Suppose you have at least one parts list in the active drawing.
Run this VBA sample. It gives you access to the content of the parts list cell by row and column numbers.
In this sample Row number = 5, Column number = 3.
Property Value of the PartsListCell object is read/wrtite. So you may assign your values to it.
Private Sub AccessToCells() Dim oDoc As DrawingDocument Set oDoc = ThisApplication.ActiveDocument Dim oSheet As Sheet Set oSheet = oDoc.ActiveSheet 'reference to the 1st parts list Dim oPartsList As PartsList Set oPartsList = oSheet.PartsLists.Item(1) 'collection of all rows Dim oRows As PartsListRows Set oRows = oPartsList.PartsListRows Debug.Print "Rows Count: "; oRows.Count 'reference to the specified row Dim oRow As PartsListRow Set oRow = oRows.Item(5) 'reference to the specified cell in the given row Dim oCell As PartsListCell Set oCell = oRow.Item(3) 'content of this cell Dim St As String St = oCell.value Debug.Print St Beep End Sub
Hope the idea is clear.
Thanks Vladimir_Ananyev,
We found a solution similar to the one you provided.
The only difference is it is calling out the columns in the parts list by headding name, instead of number.
' Set a reference to the drawing document.
' This assumes a drawing document is active.
' Set a reference to the first parts list on the active sheet.
' This assumes that a parts list is on the active sheet.
Dim oPartList As PartsList
oPartList = oDrawDoc.ActiveSheet.PartsLists.Item(1)
' Iterate through the contents of the parts list.
Dim i As Long
For i = 1 To oPartList.PartsListRows.Count
'look at only the part number column
oCell = oPartList.PartsListRows.Item(i).Item("PART NUMBER")
'find a specific part number
If oCell.Value = "12-345" Then
'identify the cell in the description column for the row that
'the part number was found in
oCell2 = oPartList.PartsListRows.Item(i).Item("DESCRIPTION")
'write to the target cell
oCell2.Value = "Bingo!"
End if
Next
Great!
