Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Want to get component name by selecting it in graphic window (vb.net)
5 REPLIES 5
Passi
1786 Views, 5 Replies
I don't know, what's the correct code, for getting the name of an assembly component by selecting it in the graphic window.
The user should have the ability to slect an component and Inventor will give you the name of this component (filename, Screenname or whatever :))
I need the name to go on wth it in .net.
Best Regards
Passi
5 REPLIES 5
Curtis_Waguespack
in reply to: Passi
Hi Passi,
This might work for you (note it's formatted for iLogic so you might need to tweek it just a bit):
'get currently selected component
Dim oOccurrence as ComponentOccurrence
Try
  oOccurrence = ThisDoc.Document.SelectSet.Item(1)
Catch
  MessageBox.Show("Please select a component before running this rule.", "iLogic")
  Return
End Try
Dim doc As Document
Dim CurFileName As String
'set the selected item
oOccurrence = ThisApplication.ActiveDocument.SelectSet.Item(1)
'get the selected item document occurrence name
doc = oOccurrence.Definition.Document
'get the path and file name of the selected item
CurFileName = doc.FullFileName
'defines backslash as the subdirectory separator
Dim strCharSep As String = System.IO.Path.DirectorySeparatorChar
'find the postion of the last backslash in the path
FNamePos = InStrRev(CurFileName, "\", -1)
'get the file name with the file extension
Name = Right(CurFileName, Len(CurFileName) - FNamePos)
'get the file name (without extension)
ShortName = Left(Name, Len(Name) - 4)
'get the path of the folder containing the file
Folder_Location = Left(CurFileName, Len(CurFileName) - Len(Name))
MessageBox.Show("File Name: " & Name _
& vblf & "File Name without extension: " & ShortName _
& vblf & "File Path: " & Folder_Location _
& vblf & "Path and File Name: " & CurFileName, "iLogic")
 I hope this helps.
Curtis
Passi
in reply to: Passi
Hi Curtis,
Many thanks to you.
That helps me to get it work. I will post the VB Code when it's done (Today I have to solve some other problems first).
By the way. Nice Blog. I will look into it a llittle deeper. Seems to have a lot of interesting things to discover 🙂
Best Regards
Passi
in reply to: Passi
I was looking for something like this a while back, ended up making something using vb.net.
A couple small differences that improved the workflow for me (and since using vb.net, I had the capability);
Instead of a message box, I displayed the name in the statusbar (thisapplication.statusbartext or something like that).
That way you don't have to click OK.
Instead of clicking on an item, I set to trigger when hovering over something.
At the end of the day, I could just move my mouse around the graphics window, and if it hovered over a part in the assembly, the file name, location (rev level, whatever else) would flash on the statusbar.
If I decided to click on it, it would open up a relevant intranet page with a whole lot more information regarding the part number.  Otherwise, I would hit escape to get out of it.
Just personal preference I guess, but thought it would be worth mentioning, as it may give you ideas about what your going to develop.
V.
Passi
in reply to: Passi
Hi and thanks for the idea.
Is it ok from the speed? Can you feel the vb is working while moving around? Our assemblies could be very big.
The idea you mentioned could be useful for controlling the path of the components of the assembly. A lot of users here, do not have a full understanding of vault and copying assemblies 🙂
But in my case, I need only the name of the part to start some part specific program. And that's only possible by getting the name. So the name would not be displayed on the screen.
The user will clik on a part, start the prog via clicking on an icon (or whatever, maybe the context menu, if I get access on it :D)  and then the specific program would run.
The name of the part in this case is important for choosing the correct prog to run.
Best Regards.
Passi
Passi
in reply to: Passi
Here's the code, if somebody needs it:
For external VB.net Program:
Needs Autodesk.Inventor.Interop.dll and Imports Inventor for the Class
____________________
Public Function Componentname() As String
Dim Inventor As Inventor.Application
 Inventor = Inventorlaeuft() 'Sub Function to get the active Inventor Session <-- Not given here.
Dim oOccurrence As ComponentOccurrence
Dim doc As Document
Try
oOccurrence = Inventor.ActiveDocument.SelectSet.Item(1)
Componentname = CurFileName
MsgBox(CurFileName & vbCrLf & doc.FullDocumentName & vbCrLf & doc.DisplayName & vbCrLf & doc.InternalName & vbCrLf & oOccurrence.Name)
Catch Fehler As Exception
MsgBox("Please choose a component first.")
Componentname = "Error"
End Try
End Function
_________________________________
If you need it in VBA:
Public Sub GetName()
Dim doc As Document
On Error GoTo Ende
Set oOccurrence = ThisApplication.ActiveDocument.SelectSet.Item(1)
If Err Then Exit Sub
Set doc = oOccurrence.Definition.Document
MsgBox (CurFileName)
GoTo Ende2
Ende:
MsgBox ("Please choose an Element first.")
Ende2:
End Sub
Best Regards
Pascale
