Each time when I place a part in base view, have to follow few steps; go through view label, format Text, than choose type option - [Properties-Model] and its property - [Part Number], than placing dimensions. it takes long time and very repetitive, especially, when placing a hundreds of parts and I was wondering if there is an option, to set up view label; [Properties - Model ]& [Part number], as a DEFAULT. So, each time placing a part, in base view it will come up with correct label. Also, overall dimensions, can it be retrieve using parameters of the part? Thank you!
